Nintendo DS Lite Console Logo
Posted on Apr 09, 2009
How do I reinstall system files?
When inserted, a message comes up:
"Error. System files damaged. Please reinstall system files."
What do I do?
Anonymous
Level 1:
  • Contributor 51 Answers
  • Posted on Apr 11, 2009
Anonymous
Contributor
Level 1:
Answers
51
Questions
0
Helped
25830
Points
83
Sorry,
You will have to send it back to Nintendo to have the software reinstalled on the console. There is no other way at the moment.
5answers
What is Quickbooks Error 1334?
Quickbooks Error 1334 occurs when you are trying to install, update, or repair the software program. It is one of the most common errors which you may face while you are using Quickbooks software. When this error encounters then an error message comes up which states that "Error 1344. Error writing to file. Verify that you have access to that directory." or "Error 1344. The file cannot be installed. Insert the Quickbooks CD and try to install it again".
Computer keeps restarting
The system need to be reinstalled or fixed by experienced technician. But you can try to do Recovery again, choosing Advanced options, to see where is the problem.
I'm trying to be to use the recovery manager on an hp mini to reinstall the operating system After going through the whole process for quite a while it stops and give me a message saying recovery...
Hallo! You better make a bootable USB with Windows and try to reinstall the system from it. You may have dome damaged files in the recovery partition. The bad part is that you would search some drivers for your mini after reinstall. Cheers!
I have a HP Pavilion Elite m 9357c that willnot boot up. The screen goes black and says Disk Boot Failure,Insert system Disk and press enter
If it happens that you are prompted by the following error message "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER", "No system disk", it means that the computer did not find the operating system to start (boot).
Causes:
A diskette or CD has remained in the drive
Check out if any diskettes, CD-ROM or DVD-ROM are present in respective drives, remove them and restart your computer
The boot sequence is incorrect BIOS
Enter the BIOS setup of your computer and edit the boot (boot sequence) so that the computer starts primarily on drive C:
A new hard drive was installed
In the case that a new hard drive has been installed, this message is quite normal.
Just insert the correct CD to install the system (usually Windows), then restart, while making sure the CD-ROM is first in the defined in the BIOS setup as first boot sequence.
The hard drive is unplugged
Open the system unit and check that power cable of the hard drive is properly connected.
Corrupted system files
It may happens that some system files needed to boot the computer have been deleted /damaged or that the boot sector of the disc is damaged.
To determine this, start the computer with a system disk or CD-ROM installation of Windows (via the Recovery Console), and once started, type Dir C: to check if the contents of drive C: are accessible. If its ok then the problem comes from missing or damaged files, then you just have to run the command:
fdisk /mbr
sys c:
Note that before any restoration of the boot sector with the command fdisk / mbr, (supposing that there is a virus), it is recommended to use an antivirus running under DOS, such as
f-prot.
http://support.microsoft.com/kb/166454/en-us
http://support.microsoft.com/kb/69013/en-us
Damaged disk
If the hard disk or a partition is damaged:
If it detected in the BIOS setup, there is a chance that it is
not out of service.
If it is, try reinstalling the system through the installation CD, in order to reformat or recover the partition using a utility.
1helpful
2answers
My computer says: DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. What should i do?
well one or two things has happen eather your operating sys crashed wich will have to be reloaded or make sure you dont have a cd rom in the cd tray cause if it is a bootable cd it will cause the same error message chances are though you need to have windows reinstalled
1helpful
I receive the message "An attempt was made to move the file pointer before the beginning of the file." What does this mean, and how can I open this file?
in case you have started to receive this error while trying to access a particular application, please try to reinstall the application.
In case that the number of applications that are giving the error message is more.
Try a system restore to a date when these errors were not coming up.
Once you do a system restore please also try disk defragmentation.
I think this should work for you.
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
R4 Revolution card for NDS system files error
contact the people www.ndsireland.webs.com they will sort ya out
When i turn on my computer i get a error message that the stystem registry data file is missing how do i restore the registry file?
Your system is corrupted. You need to reinstall it, but first backup your data. If you can't boot into the operating system, try a live CD, I would recommend you ubuntu live CD, download from ubuntu.org (http://www.ubuntu.com/getubuntu/download), just insert it and reboot from the CD. Once the system is ready, you can copy your information to a CD/DVD and then try to reinstall the original operating system.
2answers
Ze2000
Do you have a recovery disk?
Insert the recovery disc, (if auto run starts up, just close it)
Go to Start>Run and type cmd and hit enter.
In the DOS command window, type sfc /SCANNOW and hit enter.
That will check your Windows files against the Windows files on the disc. If it finds corrupted or missing ones, it will repair or replace them. You will not lose any data or files this way. (If it will accept the disc again)
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
