SOURCE: HP 3 button wireless optical mouse
Normal
0
Turn the mouse over and find the small
rest/connect button on the bottom of the mouse and press it.
This should connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the button on
the mouse. This should be done whenever you change batteries or
glitch.
Hope this helps you. Bud
SOURCE: Constant reseting of HP Wireless (P2360AA) USB Keyboard and Mouse Kit
check some Option Driver's control Panel system - Hardware - Device Manager - go to Keyboard's Up Date Drivers your Problem Solove ok
SOURCE: Replace Battery Message
It's a bit iffy, but if you go into the task manager (press ctrl-shift-esc) and look at the list of processes there will be one running called kbd.exe. This is HP's keyboard and mouse driver which, as far as I can tell, does very little but cause a world of pain. If you end the process (select kbd.exe from the list and hit the end process button at the bottom and confirm you want to when prompted) the warning disappears. Nothing else untoward seems to happen.
Jason
SOURCE: HP Wireless optical mouse stopped working
You will need to "pair" it with the receiver. Look on the receiver and you will find a button. press it then press the button on the mouse.
Then wiggle the mouse around. You should see the pointer move.
