Question about Toshiba 55H70 55" Rear Projection Television
Hatchi old rear pro picture tuns into a funny shape
Ok my set is old some time the set will look like a old sand timer it will get a real weird shape the red and bule will be left and right like an hour glass the coners will not have any picture like it all gets sucked in the middle does any one know if the tv is junk some time it even fixes it self and goes to reg.
  • 375 Answers
Re: hatchi old rear pro picture tuns into a funny shape
The set requires repair of cold solder connection and possible a set of convergence ic's .call for service and ask for an estimate of repair cost.
Posted on Sep 08, 2007
0 characters
3 Points
I have a question, We bought our Hatchi 50 inch tv 3 years ago
The manufacturer normally doesn't count the lamp for the warranty, but call them definitely worth checking w/ the manufacturer. Otherwise if you need to buy a lamp you can try they have FREE trouble shooting available so you can check to make sure it is the lamp.
Apr 21, 2010 | Hitachi 50UX57B 50" Rear Projection...
I have a Sony 47 inch rear projection tv that is about nine years old When the set is turned on it has a good color picture but after a few minutes it tuns to a complete green sceen. Can you tell me what...
The green CRT may be intermittently bad or the focus screen block. Certain sony's are common to have bad CRT's. When the screen goes green does the set shut off?
Sep 20, 2009 | Projection Televisions
Rear projection tv picture quality loss
most of these sets have 3 lens for the three picture tubes inside and also a mirror---if it has never had the lens cleaned they could be dusty and this will diminish the brightness and clarity of your picture---if real dirty the picture will look washed out------most of these sets you can remove the back cover(unplug set first) and gain access to the lens ; clean them with a lens cloth or a paper towel with glass cleaner.
Aug 16, 2009 | Projection Televisions
No picture, funny noise
The funny noise is probibly the balist trying to strike the lamp. It will try several times to strike the lamp and if it is un successful, the lamp light will begin blinking on the front of the set. If so you have a bad bulb
Jul 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Burning plastic smell, colours way off, picture way off & skewed
Thats funny!My TV is doing the same thing,but now I hjave no picture just sound!
Sep 01, 2008 | Akai PT5598HD 55" Rear Projection...
Mitsubishi WS-55809
can you post a picture of what the picture looks like? If so I should be able to diagnose the problem
Apr 30, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Most of the time the picture is completely distorted and you can't make out any picture. Other times the picture is perfect. The TV is a Samsung HCN617W DLP
possibly a bad color wheel.
does it make any funny whining noises?
does it do it on all inputs?
how exatcly is it distorted? is it moving up or down real fast or is it all real funny collered?
Mar 19, 2008 | Projection Televisions
Problems with dimming picture on Hatchi Rear Projection Televisions
What is the model of your Hitachi and how old is it? If is a DLP you lamp is going to need replaced.
Feb 07, 2008 | Projection Televisions
Nice description. Is the picture still square or does it have like an hourglass shape to it? If so, one of the convergence amps has failed (common problem) and needs replacing as well probably the fuse resistors feeding power to it. Probably a job for a pro as it needs to be reconverged afterwards. Can give you DIY instructions if you are OK at soldering.
Is the picture foggy as well? Have him replace the crt fluid while he's in there. How old is this TV?
Jan 23, 2008 | Zenith R56W36 56" Rear Projection...
Mitsubishi 6071 April 1994 NEED HELP!!!
these sets have bad connections in the picture yokes take the spekerr grill off and front cover move the wires around and see if the pic comes back be careful ok
Oct 03, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
18 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
