Question about Sony Ericsson Walkman® W880i Cellular Phone
Sony Ericsson W880i - micophone does not work
I spilled Tia Maria liqour on my W880i this summer so I opened it and rinsed with electronic rinse spray. Problem is that the mic isn't working anymore. When I make a call I hear them, but they can't hear me. I've ran the microphone diagnostic from the service menu and as I thought it report is as faulty. Where is this microphone located and is it possible to replace it? I can't find any service/maintainance-manual for it on www. Anyone got it or have a solution?
  • 1 more comment
  • pgeordiemac Nov 27, 2007
    microphone on my w880i seems to be faulty as nobody can here me??how can I resolve this problem?
    microphone is faulty on my w880i.no one can hear me?how do I resolve this issue?
  • Anonymous Mar 19, 2008
    hi,
    I dropped some water on my phone and the mic doesn't seem to be working, the caller on the other side cannot hear me but i can hear them clearly.
    please help!
    thanks
    Tasneem
    Problem Solver:
  • 16 Answers
Go to sonyericsson.com
Posted on Mar 06, 2008
Sonyericsson.com? Thanks a bunch.... That won't help at all.
I located the microphone and bought a new one from eBay. The problem is that when I took the faulty one off some soldering(?) paper that was located underneath it came with it and was ripped apart, so I guess it's no use trying to replace it anyways :(
I'm not really a skilled soldering person...
SOURCE:
No power when switched on new switch fitted
Dear Sir,
The power washer stops when the gun is closed. This happens because pressure is exerted on a control valve (Spill Valve)...which in turn touches a micro switch and cuts electricity. Now most probably your machine is dead because the spill valve is stuck down and closing the micro switch. This happens when one stores away the machine with pressure still in it. NEVER store a power washer with pressure in it. The spill valve also gets gammed because left with soap and machine not rinsed. I rarely service spill valves...I change with a new one.
To locate the spill valve open cover (using a TORX T15screw driver)...and where you see 2 wires coming out...there is the spill valve. If you can manage to do this..you can try if you want to lubricate it by spraying SILICON spray. If you get it out..you use silicon grease.
Sometimes these machines have the spill valve incoporated with the head....in that case the whole head must be renewed.
Regards,
Fulltech.
Apr 11, 2011 | Karcher K2.26 Electric Power Washer
My 'k' pressurewasher keeps cutting out
Dear Sir,
The power washer stops when the gun is closed. This happens because pressure is exerted on a control valve (Spill Valve)...which in turn touches a micro switch and cuts electricity. Now most probably your machine is cutting out because the spill valve is getting faulty or stuck down and closing the micro switch. This happens when one stores away the machine with pressure still in it. NEVER store a power washer with pressure in it. The spill valve also gets gammed and faulty because left with soap and machine not rinsed. I rarely service spill valves...I change with a new one.
Sometimes these machines have the spill valve incoporated with the head....in that case the whole head must be renewed. I wish to tell you to try using the machine without the lance. If it works correctly, then you have a faulty nozzel in the top of the lance. IMPORTANT...never run a power washer with water being fed!!!!
Regards,
Fulltech.
Mar 15, 2011 | Karcher K2.26 Electric Power Washer
Oversudsing
Rinse aid setting too high or has been spilled. Turn the rinse aid dial to a lower setting or wipe the spill.
Incorrect detergent. Ensure that you use a detergent that is intended for a domestic automatic
dishwasher.
Egg yolk. Place an extra tablespoon of detergent in the dishwasher door for pre-rinsing.
Too much detergent. Use the recommended quantity of detergent.
Feb 19, 2011 | Dishwashers
Position for rinse aid
Pl refer the user manual. Rinse aid is not a day to day to fill. It has a different location. Open the door and see whether you get any box visible!
May 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How tochange the mic in sony ericsson w880i
Dear, its very easy to change the mic so if you don't have any experience of mobile fone repairing or opening a mobile fone so you just don't open yourself ok. so just go to a mobile fone repairer to fix your problem, its not very expensive...Thanks
Apr 15, 2010 | Sony Ericsson Walkman® W880i Cellular...
When washer goes into the rinse cycle it won't fill it contue to try and fill but won't
Check your manual. Some washers don't fill when they rinse, instead, they spray rinse. While the tub spins, they spray water in every few seconds until the cycle is completed. This is also how the second rinse works on a lot of models.
Dec 01, 2009 | Whirlpool Washing Machines
Where do I add my rinse agent???
I have the same dishwasher, KUDS01FLSS. All you need to do is pour the rinse agent (We use Jet Dry) directly into that circle like plug with the line through it that you mentioned above. It acts like a funnel.
Pour the rinse agent in slowly as it takes time to drain into the dispenser. Just watch the little sight glass to the right of the rinse agent fill funnel. It will begin to darken (or turn blue if you use Jet Dry) as the dispenser starts to get full. I just pour it in slowly and when the rinse agent does not flow down the funnel any longer, it is full. Be sure to wipe up any spills or excess rinse agent. Hope this helps you.
Good Luck,
Tom
Jan 08, 2009 | KitchenAid 24 in. KUDS01FLSS Built-In...
No water going in to dishwasher when rinsing
the pump shouldn't turn on when the rinse cycle is on - it uses only fresh water straight from the water line - after the wash cycle is over - wait 5 seconds, then open the doors and see if there is any rinse coming out of the rinse arms.
If only a little is coming out - check the rinse arm spray jets to see if there is debris caught in them -
if no water is coming out - it could be a faulty rinse solenoid
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Sony Ericsson Walkman® W880i Cellular Phone Logo
461 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
