I could locate only 2 visible screws to disassemble the unit without removing any of the decals on the back of the unit.
Did you get it open? remove the two screws. Those are all the screws on the outside. Gently pry the halves apart at the bottom of the unit. Gently try a flat screwdriver. GENTLY! Theres some tabs that hold the rest together. You may break one or two but will be ok in the end. Do the prying at the bottom so you dont break the tabs at the top.
This is from a different thread, but is the answer
JVC KT-SR2000 backlight repair
My unit is a 3000 not a 2000 unit, and the insides do not look like the picture that shows where to solder the joints on the 2000 unit.
