Question about Panasonic ET-LAE500 Projector Lamp for PT-L500U, PT-AE500
Pt-ae500e new bulb installed but switches off after 10mins
Installed new bulb into projector. Hours reset on bulb but, the projctor is still reacting like it requires a new bulb as the bulb switches off and the red flashing lamp led indicates that their is a problem with the bulb.
5 Suggested Answers
SOURCE: PT-D3500E Projector
no havent fixed this problem but also unwilling to pay for advice.
this is something that should have supplied by the contractors who installed and fitted
the said products. many thanks for getting back to me but i will now take this up with the project manager.
Posted on Aug 22, 2008
  • 10594 Answers
SOURCE: After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Posted on Nov 18, 2009
SOURCE: hi, my projector has worked fine until
I also have this same problem, I even fitted new lamp, did yuo get this solved
Posted on Mar 02, 2010
SOURCE: is this blue tinge on the left side of the screen
Your problem is the optical block failing. This is very common with the AE700s. It actually happened to me once before and I had it fixed. After having it replaced, it was recommended I run my fan on high mode, run the lamp on low mode and change the back lit color to black from blue to help thwart the issue. The optical block fails due to heat stress from the projector. Doing the things above lower the heat and extend the life of the block. I have a perfeclty good optical block if you would be interested as buying them new are extrememly expensive.
Posted on Jul 07, 2010
  • 55 Answers
SOURCE: red lamp or heat light is flashing while projector
Here is some information on this model which I hope will help...
The lamp indicator lights when the lamp is due to be replaced. It will flash if a circuit abnormality is found.
The temp indicator lights if an abnormal temperature is detected. If it goes too high it will shut down flash.
The lamp indicator is furthest away from the power switch if that helps.
If the lamp timer was approaching the end of the lamp life you would see a REPLACE LAMP nag screen when the projector is turned on. The fact that you have not mentioned this suggests that this is unlikely to be the problem.
The filters on the model are on the underside. There is a removable panel directly under the lens. You should not use canned air as you are blowing dust into the projector. It is recommended that you use a vacuum cleaner. Filters should be cleaned every 100 hours and replaced when the projector is relamped. You can wash the filter by hand with water only, ensuring it is dry before replacing it. Do not run the projector without the filter in place.
Posted on Feb 21, 2011
0 characters
1 Points
How do i reset the lamp hours after installing the new lamp
Turn on the projector
Press and hold the ENTER button for 3 seconds.
Turn off the power.
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Aug 23, 2013 | Panasonic Lamp for PT-LB80 Projector
On the PT-56LCX16 isthere a PIP button?
usually in menu under reset filter and lamp hours.
Jan 24, 2013 | Panasonic 2 Projector Lamp
Reset lamp counter on F100 lamp
the timer chip for the lamp is on the housing of the lamp
you need a new timer chip
you can not reset the timer in the Menu setting
Have a good day!
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Nov 07, 2012 | Panasonic Et-laf100 Lamp For Pt-f100...
Go to menu > option > lamp hours. Then press enter on the Lamp Hours for 5 seconds. A new option will pop out asking to reset lamp
Dec 14, 2011 | Panasonic Projector Lamp for PT-LB60,...
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
How to get rid of little blue dots on lower left of screen pansonic et lae500 projector - will they go away when I get a new lamp?
This is most likely caused by dust in the optics - you will to remove the cover and vacuum inside - I would recommend against dismantling any of the optics in case you cannot align it again correctly.
Mar 09, 2010 | Panasonic ET-LAE500 Projector Lamp for...
Panasonic PT-60LCX64. What would happen if you
you won't get another warning for 2000 more hours on a lamp that is good for only 2000 hours (give or take). so, if you don't replace it, you run the risk of the lamp exploding at the end of it's life, sending shards of glass and mercury dust throughout the projector.
Nov 09, 2009 | Mitsubishi VLT-XL2LP Projector Lamp for...
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Panasonic ET-LAE500 Projector Lamp for PT-L500U, PT-AE500 Logo
121 people viewed this question
Top Panasonic Projector Accessories Experts
Electro Med Services...
ray gallant
Are you a Panasonic Projector Accessory Expert? Answer questions, earn points and help others
