Home | Panasonic | NV-DS60 Mini DV Digital Camcorder | Problem with Pla...
Panasonic NV-DS60 Mini DV Digital Camcorder
Problem for Panasonic NV-DS60 Mini DV Digital Camcorder
Problem with Playback and Record on camera
By feeeona on Sep 08, 2007
Hi
We are having troubles with recording and playing back on our video camera. It records for about 5 seconds then stops and the power light then flashes and won't do anything. The same thing happens with playback. We have plugged this into direct power and it doesn't make any difference, nor does a video head cleaner disk.
Any help would be great.
Comments:
Feb 21, 2008
- Hi
Yeah I found that solution on the net after a while. Very frustrating problem and such a simple solution. Thanks for confirming the things we did!! It appears to be working fine now.
Top stuff!
Same Problem
May 18, 2009
-   i have the same problem with my nv-ds60, switchs off after 5 seconds when you try to play or record.-   jameschurchi
May 07, 2009
-   we are having problem in recording & playback with our camera its recording only for 15 second & then automaticly stooped-   Guest
Dec 03, 2008
-   Thanks a heap. Solved the problem in 10 mins as you said!
-   laurie4281
Feb 26, 2008
-   My camera appears to record but does not playback can you help-   dibbled
Best Solution
posted on Feb 21, 2008
Helpful)
PanaReparMan
Rank: Wiz
Rating: 91%, 54 votes
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Was this helpful?
Yes
No
6 people thought this was helpful
Popular Solutions for Panasonic NV-DS60 Mini DV
Questions and Unsolved Problems for Panasonic NV-DS60 Mini DV
Do you recommend Panasonic NV-DS60 Mini DV Digital Camcorder?
Answer
Answer
When I try to playback or record I can't see anything I have got tapes that I know have stuff on but... (More)
Answer
How do you upload to a PC from a Panasonic NVDS60 video camera?
Answer
I have a nz-ds65a. When i playback cassette it stop after 10 sec and the power light flashes
Answer
hi i have a panasonic nv-ds60 digital camcorder, when i try to use the camera for any function be it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic NV-DS60 Mini DV...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 870
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
