Question about Kirby Ultimate G Bagged Upright Vacuum
Prying out the Roller?
I'm trying to change the belt on my Kirby Diamond Series Vacuum.I read on here how to change it but I can't get the roller out!How do you suggest I pry it out? Thanks! Tiffany
  • Tiffany25 Sep 08, 2007
    I was able to pry it out using the flat end of a spoon(not quite the jaws of life:-)It was really in there tight but I finally managed it pry it out.From there it was easy following the directions posted on here.Thanks for the help!
    -Tiffany
    Problem Solver:
  • 7 Answers
Hi There, There should be no need to pry it at all. The best way to get it out is to pull with either end at the same time and it should pop straight out. Also if the old belt is still on use that to pull the roller out. Many Thanks Chris www.elidistribution.co.uk
Posted on Sep 08, 2007
SOURCE:
Tip
How To Replace The Belt On a Kirby G6 Generation Vacuum Cleaner
Greetings,
Below we have recorded a video on how to replace the belt on a Kirby Generation Series G6 Upright Vacuum Cleaner. This easy to understand video will explain step by step how to change the belt, as well as service the roller brush. Learn how to lower the brushes as the beater bar wears out, and how to prolong the life of your belt by doing regular maintenance on the roller brush.
The repair is the same for all Kirby Generation Uprights. I hope this helps everyone! Feel free to contact us if you have any questions about vacuum repair.
If this video was helpful, please be sure to rate it as helpful by clicking the thumbs up icon at the bottom of the repair. Thanks for watching!
Chris J.
GoVacuum
on Mar 20, 2010 | Kirby G6 Bagged Upright Vacuum
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby G series diamond edition. There seems to be no suction when I turn on the vaccum. The bag inflates, but the roller does not turn. It has a new belt and the roller brush is clean. Any...
THE IMPELLER LOOKS SHOT.. 25 QUID FOR NEW ONE,,LIFT THE LID AND TURN THE ROUND PIN AND CHECK FOR RIDGES ROUND THE WHITE IMPELLER,,IF NONE THERE THATS IT,, HAPPEND TO ME TEN MINS TO FIX GEORGE
Jun 02, 2011 | Kirby Ultimate G Bagged Upright Vacuum
How to change belt on the kirby ultimate g series diamond edition?
Hi There,
Here's a very helpful video that we've shot showing you exactly how to replace the belt on a Kirby Generation series, including your Ultimate G. The video also shows you how to perform basic maintenance on your roller brush to prolong the life of the belt as long as possible. If you haven't already purchased a belt, and need to buy a new one, here's a link to the exact belt that's used on your repair:
Kirby Generation Belt:
http://www.govacuum.com/kir184.html
Here's the video:
If you have any follow up questions, please feel free to use the comment section on this repair page, I'm always happy to answer follow up questions.
If this video helped you, please be so kind and rate my repair, or leave feedback for me. This is greatly appreciated.
Chris Jones
GoVacuum.com
May 01, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I have problem with the belt and roller how to put
I read the fixit website about getting the roller off on maybe a newer version of Kirby vacuum cleaner is there a solution for the same problem with the Utimate G?
Aug 17, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Feb 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do you install the belt on the kirby vacuum?
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Nov 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Diamond Edition
If this is a Hoover vacuum, which model is it?
Jan 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Roller brush doesn't move
Here is a online guide....it's for the G series Kirbys. They're similar enough that it should help. Pay special attention to the belt lifting process...it's exactly the same as for the Heritage II, and it's also where I think your problem lies. I have a Heritage II manual available too! Hope I have helped...
Marci
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Oct 26, 2007 | Kirby Heritage II Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
71 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
