Question about EliteGroup GeForce 6100SM-M Motherboard
When i power my computor down it , just turns back on
IM having problems with my PC. When i power my pc down ,. It justs powers it self back on.
    Novelist:
    Champion:
  • 231 Answers
Hi, check the on / off switch, it is most likely sticky. To test it open your case and trace the wires from the switch to the motherboard. unplug the power switch wire and bridge the 2 pins together, this will start the computer. then power down and if it shuts down properly then clean or replace the switch. Regards mistyman
Posted on Sep 08, 2007
M4A785TD-M EVO Motherboard will not boot.
Hi
From what you are descrbing it sounds like a PSU issue
Please try the following
1) Remove all the wires from the PC
2) Press and hold the power button in for about 10 seconds (yes i know there is no power :) )
3) Plug everything back in and retry, if it still fails the Power supply will need to be changed
The Power supply can be swapped out at any decent PC repair shop and is quite cheap to do
I hope this helps
Mar 08, 2010 | ASUS M4A785TD-V EVO Motherboard
HAVING BEEN WORKING ON COMPUTOR.WENT AWAY LEAVING COMPUTOR ON .ON RETURN COMPUTOR HAD GONE DOWN .UNABLE TO RESTART COMPUTOR .HAVE TRYED NEW LEAD AND AND CHARGER.COMPUTOR 18 MONTHS OLD.
HI,
Remove your battery and then connect it with the charger to the power outlet,press the power button for 30 sec and it should turn on.
Let me know the result.
Aug 27, 2008 | HP Computers & Internet
PROBLEM: THE COMPUTOR SHUTS OFF A FEW MINUTES AFTER THE ADAPTER CORD IS UNPLUGED. BATTERY IS NEW AND READS 75 TO 1OO% CHARGED. CPU FAN IS WORKING. WILL NOT TURN BACK ON UNLEES ADAPTER CORD IS PLUGGED BACK...
Activate low power usage in Bios and also check that the power setting iis adjusted so that PC doesnt "shut down when power is low" this can be found by rightclicking on the desktop,choosing properties then power ...
Jan 27, 2010 | Dell Inspiron™ E1505 PC Notebook
Hi i have a a computor hasn't been used for about
Please try to check your memory bank , pull the memory and clean it with an eraser, put it back firmly.Please check the unit again.
Jan 26, 2010 | Computers & Internet
Just hooked up my pc yesterday worked fine. I shut down by going to start & turn off computor. Came back later to start back up. Monitor tells me in power safe mode. Tower doesn't seem to be starting...
You can try removing external devices like (ex. usb printer, external Hard drive) and try to start the computer again. And see if there are lights on the tower
Hope this helps
Jan 03, 2010 | Dell E173FP 17" LCD Monitor
Computor will not come on. green light in back is
This sounds like either your motherboard or power supply is shot, if it is still under warranty you can get HP to send you a new power supply or send your PC back to them and they should fix it for you.
You can check your warranty status online on HP's website here.
Hope this helps.
Nov 13, 2009 | HP Media Center m1180n PC Desktop
I have a half white screen and the other half is usable..!
You mom will not kill you, the fault was probably not caused by you (you can tell her I told you)..
The fault most likely a faulty video chip on the laptop or a faulty connector between the laptop motherboard and the LCD screen. You can connect the laptop to an external monitor and the power the laptop up, if the image on the monitor is OK then the video chip is OK.
If the laptop is new then it should be under warranty, get it fixed or replaced.
Nov 15, 2008 | Compaq Evo N800c Notebook
Light
I don't know Samsung's warranty policy for Australia so I'd email them right away. It could be an input voltage problem. It could be heating up components in your equipment causing it to shut down and reset when it cools off. As the green light is not even coming on may be an indiction of this. So I'm guessing you are currently shortening the life of your equipment. Rich
Sep 20, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Advent 9912- Powering up
it looks like theres an easy solution to ur prob though I havnt got full details.
what pc world did is common.but you either know this or dont and u will never know until ur told.
I went into pcworld once and asked for some dos disks,they looked at me like ive two heads and informed me that dos doesnt exist,I didnt know whether to laugh or punch their lights out as Im a computor technition and use dos platforms quite often.in xp repair at startup this is a dos platform.almost every outside of windows to repair pc's is a dos.
Anyway if ur looking for a manual that explains everything about ur pc and has a very informative trouble shooter;get back to me with ur model details and I'll mail u one.
Apr 06, 2008 | Computers & Internet
EliteGroup GeForce 6100SM-M Motherboard Logo
50 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Computer Links
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
