Home | Lexmark | X125 Pro All-In-One InkJet Printer | Lexmark x125
Lexmark X125 Pro All-In-One InkJet Printer
Problem for Lexmark X125 Pro All-In-One InkJet Printer
Lexmark x125
By jerrywater on Apr 09, 2009
error msg: add left cart and memory to print. when fax come in it does not print but goes directly to memory
Solution #1
posted on Apr 10, 2009
Not Rated)
Roop1980
Rank: Wiz  Lexmark Expert
Rating: 84%, 209 votes
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Was this helpful?
Yes
No
Popular Solutions for Lexmark X125 Pro All-In-One
Questions and Unsolved Problems for Lexmark X125 Pro All-In-One
Do you recommend Lexmark X125 Pro All-In-One InkJet Printer?
Answer
Answer
have new hp competor no disc to download can you help me,
Answer
printer worked fine i had to unplug it and when i plugged it back in it says add left cart. the... (More)
Answer
Is the Lexmark X125 compatable with Windows Vista or not?
Answer
Printer won't print envelopes. Prints everything else just fine. What am I doing wrong?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Lexmark X125 Pro All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
