Question about Danby DPAC12031 Air Conditioner
Pump doesn't seem to work anymore...
Had no problems with my Danby portable AC for the last 2 years (of course, just past warranty now!). Recently, I noticed I didn't hear the clicking sound of the waterpump doing its 'showering action' over the coils. I thought it was temporary until the units beeped that the water (side) container was full! I've never seen so much as a drop in there before. Also, the "P" symbol never shows up either. So, I can still use it, but the efficiency is much less, and I have to keep emptying the side container. Since I'm just past warranty and even though year 3-5 covers parts only, is there something I can check myself? Maybe a relay or switch burned out? Maybe something clogged? Is the pump itself broken? I just know taking it in locally will be (other than a real pain) an expensive trip even if the part is covered under warranty. Thanks to anyone who can provide some help or perhaps has seen this happen before...
  • 2 more comments
  • tron2010 Sep 11, 2007
    Guess what...I think I have solved it. All of a sudden the "V" and "P" showed up at the same time and the manual says that this is a 'fault condition' and to try emptying the bottom drain of water. So I started with the garden hose cap on the upper part of the back... lots of water came out. Then a drip pan under the bottom-back drain...lots of HOT water there...and I noticed (to comment on kstfas--thanks for the tips) greenish/alge buildup in the drain-tube... so after emptying all water from everywhere possible in the unit, I qtipped all openings as much as I could... I don't know of any way to get vinegar into the pump itself. So, after unplugging and restarting...after 15mins I heard the familiar pump 'click' and saw the "P" show up! And I could hear the water being pumped. All is great now for the last 24 hours. And no water collectiong in the side bucket--whew!
  • Anonymous Aug 23, 2008
    Same deal, unit never filled up the reservoir, now it does.  Still working on resolving the issue.
  • Anonymous Mar 25, 2009
     Last year the condensate tank started to fill up rapidly (not usual) so I figured the pump or hoses to the coils had become clogged.  I ran a hose into the two lower drains, which solved it for the rest of the season. (Caution, do NOT overfill, I just used short blasts of water).
    I decided to inspect it now before the summer starts.  There are two pumps in this unit based on taking mine apart, one in the front that has a hose running to the coils and one at the back with a hose that runs to the external tank outlet (not easily removable).  It is easy to remove the front pump, which I found to have a lot of crud & hair wound around the impeller.  I removed that and put a drop of oil on the fan shaft.  Hopefully this will now be reliable. There was a lot of sediment buildup in the water tray at the bottom also.
    I was not impressed by the assembly quality of this unit.
  • rikedoid Mar 25, 2009
    NB: Disassemble at your own risk!
    Novelist:
  • 75 Answers
Hi, I'm not familiar with your unit and have been waiting on someone else to answer your question but it doesn't seem to be happening so here goes..... Could be a buildup of lime in the pump or the lines to and from it. I would try using some white vinegar in the tank and see if this will clean it up. If you can get some into the pump itself, It may help. If you check the manual, It mat suggest something like this or have a service # where you can get more help. I hope I have helped. kstfas
Posted on Sep 10, 2007
Problem with Fujitsu minisplit heating
did you try to set to maximum heat? (suspect the thermostat is defective)
Oct 03, 2015 | Fujitsu AOU24RLXFZ Dual, Tri and Quad Zone...
Having some problems with my portable dandy airconditioner not working properly
And what are the problems you're having with your Danby Portable AC, Carmen?
Aug 15, 2011 | Danby Portable Air Conditioner
Our Danby model dpac 11006 was working fine yesterday but came to put it on today just to find out the ac doesn't work the fan still blows just no cool air . we do hear something in and out like a...
The intermittent sound you're hearing is probably the compressor trying to start. This could be caused by a bad circuit or the compressor motor is seized If the latter is the case, it's time to start shopping for a new AC. As the cost to repair would be almost as much as a new unit depending on the age of your unit. However, compressors usually have a 5 year limited warranty. So check you Owners Manual for details. It may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Danby Portable Air Conditioner
Danby Portable A/C Model DPAC 11007, purchased Costco May 19, 2007. Platinum Warranty. For the first few years A/C( only) operating it was not necessary (or rarely) to empty the external tank Then last ...
Eugene, first, let me say, yours is one of the best narratives, of what is happening with your ,that I have read in a long time. You didn't leave me guessing as to what was going on.
I believe one of the problems is that you may be operating the AC Cooling & the Dehumidifier at the same time. If this is the case, the dehumidifier is generating heat, when it's operating and the AC cooling side is working at a lower rate, because the dehumidifier is in operation. Discontinue the use of the dehumidifier on extremely hot days and use only the AC Cooling mode. The AC mode also acts somewhat as a dehumidifier. That's why draining the water tank is required for AC mode too.
I would also be prudent to check the exhaust hoses to make sure they are not clogged or have been bent out of shape. Keeping the air intake filter clean is really important, too.
Aside from the air conditioner, other things can be done to help cool the room. Close all drapes or blinds to block the sun from directly heating the room. This is especially true, if the AC unit is sitting in direct sunlight. If you have a ceiling fan, operate it it as fast as you can stand, in a Clockwise direction. This not only keeps air moving, it also helps the AC unit and creates a windchill, that fools your body into thinking it's cooler than it really is. Personally, I have been doing this for years and have saved a ton of money on electric bills during the summer.
I hope I have been able to help you and thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
Need my users manual
Here is a link to a 12,000 BTU, Danby Portable AC Unit. Since you failed to mention the model number of the unit you have, I can only guess that is the same as yours. In any event, all Danby Portable AC units work the same. You can download and print this manual for future reference.
http://www.danby.com/cms/uploads/products/en_manual/DPAC_12099_EFOM.pdf
I hope this helps you and thanks for choosing FixYa.
Jul 23, 2011 | Danby Portable Air Conditioner
Although I know it is not recommended, I have no choice but to plug my AC into a surge protected power bar/extension. I have done so for the last 2 summers, no problem. I take out my AC to install, last...
The best thing I can tell you is, that Danby does not recommend it. Even an extension cord is not recommended, unless it is a 14 gauge and no longer that 6 feet.
Several questioners in the past, have used a surge protect power bars and ended up frying the electronics of their AC units.
But, in the end, it's up to you.
Jul 13, 2011 | Danby Portable Air Conditioner
I have a Danby Silhouette 10,000 BTU portable A/C.. it has recently stopped turning on. The panel with buttons lights up and works, but the unit itself will not turn on. Any ideas on what the problem is?...
If the unit was set in Automatic Timer Mode, it will not turn ON until the set time is reached. Try deactivating the Timer Mode. If that doesn't work. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. During this timeout, the unit should have time to reset itself, so that when you plug it back in and turn it ON, it will have reverted back to the original factory settings.
If you have misplaced your Owner's Manual, I have included a link to a Danby Model that is similar to yours, in the way that it functions. You can download and print the manual for future reference if you like.
http://www.danby.ca/cms/uploads/products/en_manual/DPAC10011_DPAC10011BL_EFOM_v2.pdf
I hope this helped you. Please let me know. Thanks.
Jun 28, 2011 | Danby DPAC10031 Silhouette 9,000 BTU...
Air conditioner seems to have a programming short
of course you tried pulling power plug for 30 minutes...?
Jun 01, 2007 | Danby DPAC12031 Air Conditioner
Danby DPAC12031 Air Conditioner Logo
180 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
