Question about Technics SL-1210MK5 Turntable
Speed regulator. I have a technics 1210 mk2. The turntable speed has started to osolate. This happens at any speed. Do you have any ideas???
  • 515 Answers
First and foremost, are you located in the U.S.? If so, make sure your unit's voltage is set to 115V rating. The switch is located under the turntable platter. All you need is a flat head screwdriver to turn it to the proper voltage. If it's on 220V, you need to change it. If you are not in the U.S., or it is already set @ the proper voltage rating, your problem could be one or many issues with the drive, and pitch control. There are various resistors, capacitors, IC's and variable resistors, which control the drive. Any one of these could have gone bad on you. Do you have a runaway operation, or is it doing that back and forth movement? In either case, this cannot be self repaired, and you will have to take it to a qualified service center for repair. Cost will run you anywhere from $60-120 - if they go higher than that, they either do not know what they are doing, or they are trying to pull one over on you. We work on these on a daily basis, and should cost you more than that. However, prices do depend on where you live (we are in NYC). Good luck!
Posted on Sep 23, 2007
Technics sl1210 mk2 motor speed error
pls use the search function, this is answered 50 times
Jan 08, 2014 | Technics SL-1210 Turntable
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Apr 04, 2009 | Technics SL-1210 Turntable
Turntables lags on pick up
I have the same exact problem with one of my 1210 MK2 turntables. It seems like the motor is too slow now. When I hit the start button or release the record, it takes much longer to speed up to the normal speed than my other same exact turntable. I don't think it has anything to do with the pitch slider. Please let me know if you find out what the problem is thanks!
Mar 18, 2009 | Panasonic Technics SL-1210MK2 Turntable
Poor quality sound
Double check all your cables. The only 2 things that affect sound on the 1200s is the RCA cables and the tonearm. I would first replace the RCA cables to a better quality set.
- OPTiC
Technics Repair Videos
Technics Turntable Repair
DJ Equipment Sales
Technics Parts Sales
Jan 16, 2009 | Technics SL-1210 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Technics sl 1210 MK2 does not start
Your switch probably went bad. Does it not respond at all? Does the button at least 'bounce' back when you press it? If not, then you might have messed something up when putting it back together.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
Technics 1210 mk2 problem with pitch and lights
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Nov 30, 2007 | Technics SL-1210 Turntable
Technics SL-1210MK5 Turntable Logo
166 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
