the manual covers this, it tells you to read alarm event code
messages they are not in number format but text.
in clear english the alarms.
RTM or call EATON, we are Fixya not EATON,ok>
most error common means bad batteries. 99% are.
What kind of car are you asking about and are you buying it or do you own it? Most times that a battery is disconnected is to prevent drain, usually a parasitic drain caused by computer, if storing for a long period of time or many times the disconnect is to try to clear a computer code. The problem with doing this can cause the computer to do an anti theft lock out that will prevent the car from starting. Especially a Chrysler or Dodge.
according to my reading, a flashing power lights indicates a problem you can solve on your own. while a error like you typed would mean something that you cannot resolve without help. a problem like a bad controller, or a bad chip. maybe a eeprom issue.
If Call service appears, turn off the printer, disconnect the power cord, and contact your service technician Some errors cause the alarm to sound. To stop the alarm, press [Cancel].
#### represents a mechanical error (#=0, 1, 2, ...). Call for service. The printer does not operate when this message is displayed. The total number of pages printed is also indicated, e.g. 0123456.
This woiuld mean you printed 53103 pages with that printer before the error occurred.
It says what must be done, which is to test it with a scanner for fault codes, and no it can't be disconnected, it is deeply embedded into the systems control computer for the engine and start system.
Readings You May See When Unit is AC Powered Display Shows Alarm Sound Unit Status Recommended Action Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer and flashing dot 30 seconds AC powered service at 1-800-880-6788 Readings You May See When Unit is on Temporary Battery Backup Display Shows Alarm Sound Unit Status Recommended Action Flashing dot None Normal battery-only operation - Plug in to AC as soon as unit will show reading only if it possible to conserve battery senses CO Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer "Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here: http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Hi Thanks for using FixYa. Error F9-2 in your Gemini range means door upper latch unlock failure and to resolve this issue you'll have to check for obstruction in door lock mechanism and replace the door latch switch or assembly if required. Please do rate the solution if the issue is resolved or post a comment for further assistance. Thanks Rylee
I am having trouble also but I need to know how to disconnect the alarm. I would appreciate it if you could help me out seeing that you have disconnected yours. Thank you
