Question about Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint wireing not sure which wires go where
HI IN CHANGING THE BEARING ON MY WMA52 I GOT THE BEARINGS OUT OK ORDERED A NEW KIT BUT IM UNSURE AS TO WHICH WIRES GO WHERE. wHERE THE WATER ENTERS THE WASHER AT THE BACK THERE R THREE TERMINALS BLUE,GREY AND ORANGE POINTS TO PLUG INTO . THE BLUE AND GREY ONES R FOR COLD ORANGE FOR HOT. I HAVE A LITTLE PLUG THING WITH RED AND BLACK WIRE I KNOW THAT GOES TO THE HOT TERMINAL WHICH IS ORANGE. THE OTHER TWO IM NOT SURE WHICH GOES WHERE THEY BOTH GO TO THE COLD BUT WHICH WAY ROUND I HAVE A PLUG WITH BLUE AND BLACK AND ONE WITH GREY AND BLACK WIRES CAN ANYONE TELL ME WHICH OF THESE GOES THE GREY TERMINAL AND WHICH GOES TO THE BLUE TERMINAL
  • SIMON HENDON Sep 09, 2007
    Not quite there yet i know which solenoide is which but the wires r fixed lugs like you say only thing is im not sure which lug goes in which solenoid there colour coded but the coluors dont match the solenoids.
    black and red wire together which is colour coded red goes in the hot which im sure of solenoid is orange.
    so im left with a lug which is coded black with black and grey wire in.
    and lug which is coded grey with blue and black wire.
    can you tell me which of these goes in the cold solenoid and which goes in the conditioner.
If its just a case of plugging one in each, then this then can only be done by trial and error, plug one into the cold and one into the conditioner, close the drawer set the machine off on a rinse only, watch where the water goes, if it goes into the conditioner cup then swap the plugs round, the cold should move the powder from behind the conditioner cup, the machine will not trip, you will just work the wrong solenoid, hope that helps, sometime it says a letter on one of the wires about a few inch from the plug, but i guess you have tried that. if i have helped don't forget to rate me thank you
Posted on Sep 09, 2007
  • 209 Answers
One of the wires will be the neutral and will have 3 ends to it (spades) all linked together (follow me)each one of the ends will go to one of the spades on each one of the solenoids (taps, now you will have a space on each solenoid to connect to the Blue generally indicated cold and Grey indicates conditioner, conditioner is generally the middle solenoid, if you follow the flow looking from above it goes furthest to the front of the washer (WMA models or later only) if the wires are as fixed lugs that is 2 wires are in a mold then just match the colours, the clue is on the back of the machine it also says C or H next to the respective solenoid, hope all is ok then
Posted on Sep 08, 2007
The machine has a noisy bearing when spinning
hi to do this you have to take whole drum out of case take pully off back the drum has screws around holding front and back together when its taken apart you have to knock shaft out from back the inner drum will come out then you can get to bearings fitted in hub these can be tight to get out
Jan 29, 2014 | Hotpoint Aquarius WMA52 Front Load Washer
Tdc62
hi push the top of drum at back in side upwards if it lifts bearing is worn if so take cover of back remove wire pin to change bearing
Mar 13, 2013 | Hotpoint TDC32 Electric Dryer
How do i replace the bearings on a hotpoint ctd80 tumbledryer
if im right you have a sealed drum meaning you can not change the bearings ok you only have to take the lid off and if there's no clips or screws then its sealed ok need a whole new drum
Oct 19, 2012 | Hotpoint Washing Machines
Dear fixya, I have a hotpoint aquarius wma52 which sounds like it grinds when drum turns. I gather it may be the bearing but I don't see how to take off the back and check to replace.thankyou
HI,
First of all, is the noise only heard when the drum is rotating or when the pump is running? This really makes the difference. Sometimes an object can rub on the outer tub during rotation and cause the same noise, other times, I have found foreign object within the pump and caused the same problem. So when is the noise heard is very important to lead you in the correct direction.
I will be glad to assist you if you like
Jul 28, 2011 | Hotpoint Aquarius WMA52 Front Load Washer
I have got a Hotpoint Aquarius tumble dryer. I have just put a new belt on it and a new rear drum axle with new bearings and front bearing pads.I have made sure that the front of the drum is sitting...
Make sure that you have fitted the spacing washer provided with the bearing kit on the drum shaft, and that it is sitting between the rear of the drum and the rear bearing, double check that you have got the front of the drum sitting on all the plastic bearings at the front.
If it still catches, then fit another washer on the drum shaft to space it off from the rear of the cabinet.
Mar 25, 2010 | Hotpoint Dryers
Hotpoint wf541p bearing
ebay sell all kinds of bearing kits. about £10 usually.
Dec 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Suspect bearings gone
I do not advse you to attempt to change the bearing, it is a very involved repair, and you need to know what you are doing. the normal procedure is to change the whole drum assy.
Check with Hotpoint
Aug 10, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Bearing kit?
When you re-install the bearings make sure you use a good red appliance grease it is for high temp high speed use. Use a good amount of it then install the bearings the same way you took them out.
Jan 14, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Aquarius WMA52 Front Load Washer Logo
112 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
