Question about Motorola Mobility RAZR V3
Failed call messages
My phone is giving too many call failed error messages. it shows good antenna signal & network connection My wifes razr is older than mine & works fine even when sitting next to mine it works & mine wont
  • Anonymous Nov 13, 2008
    Not one of our phones work now. All three (two v3 razors and 1 samsung) all say "call failed" I can call 911 but not customer service.
Switch your network over to another carrier for about a hour and then switch it back. sometimes just making the switch makes your phone connect better to your tower
Posted on Sep 08, 2007
My Phone S3650 shows network error whenever i dial a number or shows message sending failed when i send a message where as it is displaying full signals.i recently got it from saudi arab to another...
Go to menu -> settings -> network settings. Go to select network and set to 'automatic'. Then go to network mode and set to 'automatic'. If this doesnt work you may have to contact your mobile operator.
Mar 10, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I bought a Razr V3 off ebay and when i got it, it says no service. what do i need to do
Hello Sir,
This message is only seen when the network or your Sim's Service Provider is out of reach. Try to check that the area in which you live in have that network's connectivity or not. In that case, try to change your Network Provider. I suggest Vodafone. Another reason can be that is your Sim's Network Service is blocked. Try to contact the service provider and tell them about this problem. They will try to unblock the service if it is blocked. The last reason may be a faulty Internal Antenna. The Int. Antenna is the device which receives the Network signals. If it is damaged, the network service will be offline. In a faulty antenna case, try to get a checkup of the phone's antenna. If it is faulty or broken, try to repair it but it will charge a fee. It will be better to contact the E-Bay seller from whom you bought it. Then take appropriate steps.
Thank you Sir,
Have a nice day.
Dec 13, 2009 | Motorola Mobility RAZR V3
My N79, got wet. Only Network connection problem.
clean your phone with alcohol,thinner or ipa liquid. Give more attentions to signal section parts,especially to water damage parts.
Nov 21, 2009 | Nokia Cell Phones
Nokia 6310i - Low and No signal
It's possible that you could fix it, but not entirely likely. It depends on whether it's just a bent antenna connector or if a circuit board is broken.
Some phones have a small spring-type piece that makes contact with the antenna. If this is merely bent, and not making a great connection, you might be able to coax it back into shape and that might fix your phone. Otherwise, it's probably beyond the ability of an amateur to repair.
Nov 06, 2009 | Nokia 6310i
Motorola razr v3 not catching signal
Have you used the external antenna port? If this is damaged it renders phone useless. Somehow connected to main antenna.
Jul 09, 2009 | Motorola Mobility RAZR V3
My cell phone has no network connection
Try this: turn off the phone & let it charge for 48hours, that will give it enough time for the electricity to dry out the internal circuitry in the phone and possibly fix your internal antennae problem...if that doesn't work then your phone's tea bath may have shorted the antennae.
Jan 02, 2009 | Motorola Mobility RAZR V3
Cant recieve my network signal
try finding a cell repair store and have them check the connections fro the antenna
Jul 10, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3 No signal (bars)
I had the same problem with my phone- i got a cheap generic battery to replace the old one (which wasn't holding a charge for a full day, at that) and then i lost all signal, basically. I tried what scm_pa said he did - charged my old battery up, with the phone off, till the charge was complete- turned the phone on, and voila, reception!
Oct 03, 2007 | Motorola Mobility RAZR V3
Motorola Razr
you need to have the internal antenna checked....or go into the network settings and change the band from auto to manual and have it do a manual search.
Aug 23, 2007 | Motorola Mobility RAZR V3
No service
i was recently told that if you use an external antenna on the razr, you can 'burn out' the internal antenna resulting in no service or intermittant service, even when in an area that normally provides strong signal, thus it may be that your internal antenna is the problem.
Dec 12, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
117 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
