Akai LCT2715 27 in. LCD Television
Problem for Akai LCT2715 27 in. LCD Television
Locked Channels and V Chip password
By tygermoe on Apr 09, 2009
several my channels are lock, how do I unlock and how do I reset the V Chip password
Comments:
Apr 29, 2009
- Thanks you for your answer, but none of the passwords worked. The message that appears when selecting for example channel 8, is 'channel be locked'.
Apr 29, 2009
- I purchased the Tv about 3 years ago at Sam's Club. It was used with Comcast cable until last year I added a digital box from comcast. About 3 mos ago it was moved to another room and attached to the cable from the wall. I rescanned the channels, now there are some locked channels. I never changed the password (on purpose) it may have been a mistake, and don't have a reason to lock any channels.
Any ideas?
Apr 30, 2009
- Yes you are correct, I am the only owner, no children, I didn't set the V-chip, so do you know how or where I can contact a service center? Also, the locked channels were not locked before and they do exist in the package because all the other TV's in the house can get those channels. Thanks again.
Clarification Request
Posted by skotkolr on Apr 30, 2009
so you are the only owner of the tv and you have no children and you did not set the v chip password to something else, well then it is still set to the default password, if someone else set it by accident you would have to contact a service center to find out if there is a default reset for the v chip password. The locked channels were not locked before? or they did not exist in your package before?
Posted by skotkolr on Apr 29, 2009
Tell me about the history of the TV.
Posted by skotkolr on Apr 28, 2009
you can try several different codes if no one has changed the password.
0000 or 5555 or 1234
let me know what happens.
Solution #1
posted on Apr 30, 2009
Not Rated)
skotkolr
Rank: Guru
Rating: 86%, 378 votes
Contact any TV repair service , they should be able to tell you the default password over the phone, if that does not work then the Television has been damaged in the main board, and most likely a replacement will be needed.
This is the best I can do for you I do not have access to this models password default setting.
let me know how it works out please.
Was this helpful?
Yes
No
Popular Solutions for Akai LCT2715 27 in. LCD
Questions and Unsolved Problems for Akai LCT2715 27 in. LCD
Do you recommend Akai LCT2715 27 in. LCD Television?
Answer
Answer
the akai at the turn on present some vertical bars and after some minutes the picture come on ok. i... (More)
Answer
model # ict3201adj. red light wont stop flashing. will not let me turn on with remote
Answer
hello i have a akai lct2715 and i cant get a universal remote to program to the tv. does the tv... (More)
Answer
i have 2 akai lct 2715 lcds that bad electricty caused some capacitors to go. I fixed the power... (More)
Answer
tv turns on, then turns off by itself - no sound, no picture 2005 Philips HD flat screen monitor tv... (More)
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
