Question about Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200)
Help plz! I NEED TO SET MY MODEM TO BRIDGE MODE CA U HELP?
  • 65 Answers
If this is because you have a dsl modem and you want to hook up a wireless router to it you will have to make this change by typing the ip address of the modem into IE and logging into the modem. There will be an area where you can set bridge mode. If you post the make and model number of the modem I can help you more.
Posted on Sep 09, 2007
    Scholar:
  • 47 Answers
Connect your computer directly to the ethernet port on the Modem. Bring up a command prompt window (you can get one easily by going Start > Run and typing "cmd" and hit ok. Then in that window, type "ipconfig /all" and look for the Gateway IP Address... type that Gateway IP into your browser address bar and log in from there. Once you get in, the setting should be pretty easy to find. Check out http://www.zhone.com/support/manuals/docs/62/6210-A2-GB21-10.pdf for more details.
Posted on Sep 08, 2007
I got a problem in connecting my samsung galaxy GT-7500 to sitecom extender 300N .. I have tried to change the IP address but it doesn't work with me . Any help plz?
Which modes are you trying to use this Sitecom? If you have the Sitecom as your Access Point (AP Mode), then you would need a LAN connection to your internet gateway (DSL, Cable Modem, etc). I didn't see any LAN hook up so I assume you are trying to use it as a wireless repeater. So you need to configure the unit differently. The 3rd mode is called Bridge mode. Again, you need to have a LAN hook up to your local network with a router or network switch.
Because your Tablet is connecting to the Sitecom okay, which mean that you either have the Sitecom setting for AP mode or Bridge mode. And the reason it didn't give you access to internet because there is no internet gateway connection to the Sitecom (LAN). I hope this answer your question (or confuse you totally).
Feb 15, 2013 | Computers & Internet
How do you change to bridge mode
If you are thinking of bridge mode that a DSL modem can be set in, cable modems are by design set up like this. Cable modems are dumb that are only made to pass the public IP address given to whatever is behind it, therefore making it always in a bridge mode.
Mar 01, 2011 | Arris SURFboard Gateway SBG901 DOCSIS 20...
Can't play other players online with PS3 because of NAT3 network configuration.
There are many reason as to why NAT3 is not open. First is the ISP's modem, verify from your ISP is set into full bridged mode. If it is just half-bridge, informed your ISP to help you set modem into full bridge mode. Second is forward the port numbers TCP: 80, 443, 5223 and UDP: 3478, 3479 in your router. You will access the set-up page of your D-link router and click "advanced tab" and choose "port forwarding"
Nov 09, 2010 | Belkin Basic Wireless Router
Bridge router
1. Use both the Modem and the router as NAT routers. Do this by making your router a DMZ node on your modem, that way ALL traffic will pass to the router, then set up port forwarding etc on the router.
2. Run the router/modem in bridge mode (recommended). You need to set the modem to run in bridge mode, check the user manual for refrences to bridging. Then set the router to connect to PPPoE using a username and password.
Jun 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Just got wpn824 and having problrms with pppoe login and pass. Using att dsl ...but that login isn't working
You'll need to set your DSL modem up for "bridge mode". Right now it's acting as a router as well and that's keeping your new router from making the connection. In bridge mode, the modem acts only as a modem to connect to AT&T. Then your router will provide your login information and your computers will connect through it correctly.
You don't give your modem model so I can't give you any specific directions. A Google search for "bridge mode" and your modem's make and model should turn up the information you need. Or you can call AT&T's technical support number and ask them how to configure your modem. (Sometimes these big ISPs aren't too keen on helping you, though. They'd rather supply you with a wireless router/modem at an extra charge.)
Hope this has helped. Thanks for using Fixya!
Feb 15, 2010 | NetGear RangeMax WPN824 Router
I have a Linksys WRT54G router. The power went out the other day and I haven't been able to establish a connection since. I can connect when I run cable from the modem to the cpu, but not if I try using...
what is the model of your modem? if you said that you are able to get online when your computer is hooked up to the modem only, then it indicatest that your modem is not yet in bridge mode. Putting it in bridge mode will make your modem a "pass through" device thereby causing no conflicts in asking for ip add/connecting to your ISP. when your modem is in bridge mode, you should not be able to get online.
after setting your modem to bridge mode, connect your linksys router. if you have a pppoe connection, or one that uses username and password, have that set up in your linksys router. at this point, your router will be the one to ask ip adds from your ISP.
you could also visit this site, http://www-ph.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=PH/Layout&cid=1166859677881&pagename=Linksys/Common/VisitorWrapper&lid=7788193882H13, for further configuration of your router. as for your modem, try to call your ISP on how to set your modem to bridge.
May 05, 2009 | Linksys Wireless-G WRT54G Router
Bridge mode
Reset your modem.
There is a reset button on the back.
Push it in and hold it down for thirty seconds with the modem on.
Log into the modem at 192.168.1.1 (admin/password=username/password)
You will need to change the modems administration username/password, doesn't matter what to since we'll make it unreachable soon enough.
On the connection overview page goto configuration.
Go to DHCP configuration and switch the DHCP server off.
Then goto configuration and click on VC configuration.
All but the first VC should be disabled.
Click on the edit or configure button next to the first and enabled VC.
Switch from either DHCP or PPPoE to Bridge.
At the bottom of the screen click on set VC.
Done.
Your modem is now in 'full bridge' mode and will need to be reset again to get it out.
Jan 31, 2009 | Westell Wirespeed VersaLink...
Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Dec 30, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Netgear wgt624 just stopped connecting to internet
I encountered the same problem, with the same modem and also Comcast, and here's what wound up working for me, after time spent with a nice guy on the Netgear customer support line:
1. Log into router: http://192.168.0.1 (or 192.168.1.1) - user: admin / password: password
2. Under Maintenance, click Router Status. If IP Address is listed as 0.0.0.0, there's your problem-- router isn't getting address from modem.
3. At bottom of Basic Settings, under Router MAC Address, change selection from Use Default Address to Use Computer MAC Address.
4. Click Apply.
5. Click Router Status again-- non-blank IP address should now be listed.
6. Basic Settings will now show MAC address under Use This MAC Address. See if you can get online now. I could, and I hope you can, too!
Dec 04, 2008 | NetGear WGT624 Wireless Router
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200) Logo
135 people viewed this question
Top Paradyne Computers & Internet Experts
Fred Steinberg
Fred Steinberg
Level 1 Expert
Marvin
Marvin
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
