Question about Sanyo DP26746 26 in. LCD Television
Sanyo tv red picture on all channels have virgin cable installed
4 Suggested Answers
  • 71 Answers
go on to the site. and check specigifactions
Posted on Mar 05, 2009
SOURCE: Cannot find freeview/digital on our new TV
problem as above please help
Posted on Sep 10, 2009
  • 55 Answers
SOURCE: how to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Posted on Nov 01, 2009
57 varieties
  • 1653 Answers
SOURCE: sanyo 46inchs lcd hdtv's color is green instead of red on cable tv
Posted on Sep 11, 2012
0 characters
1 Points
Where can I find a connector cable for my Sanyo TV model DP32242 to my Sanyo DVD player model DWM380?
Gonna need three wire connector (is red/white and yellow, yellow for video, red for right sound channel, white for left sound channel). Standard, and sold at either Walmart or Radio Shack.
Dec 31, 2014 | Sanyo Flat Panel Televisions
TV is not responding, turns on and off and does not show picture nor sound, does not move from channel 22-2
Couple of things.
  • Are you on an antenna or cable/sat box?
  • If you are on an antenna, the sub-channel of a local DTV station (22-2) was the only thing the digital receiver was able to pickup on the initial scan of channels.
  • If you are on an antenna, rescan for available channels.
  • If you are on a cable/sat box, and scanned for channels you probably picked up a like channel that is in the same bandwidth as 22-2. Probably not even a channel.
  • If you have a cable or satellite box, hook it up to one of the VIDEO channels using either a Composite AV cable (Yellow/Red/White) or a Component A/V Cable (RED/GREEN/BLUE with RED/WHITE for audio. If you are lucky enough to have HDMI for your source, use that.
  • Going forward, all of your changing channels will be from the SOURCE.
Mar 13, 2011 | Sanyo DP50747 50 in. Plasma TV
My sister has just bought me a Sanyo 26 inch TV (LCD-26XR9DA) but it won't pick up SBS and ABC jumps all over the place. I have an outdoor antennae and had no problems picking up the channels on my old...
Go to the TV setup menu and autodetect all channels. This should fix it. This is assuming your Sister is not using a set-top box.
In that case, you neet to leave the set on either channel 3 or 4, or use the video/audio input jacks and leave the set on VIDEO IN. The best picture with a non-HDMI set-top box will always be with the AV OUT from the box going to AV IN on the set [the white/red (audio left/right) and yellow(video) connections].
If she is using a set-top box with an HDMI output, connect an HDMI cable to the set and select HDMI IN for the absolute best picture.
Jan 29, 2011 | Sanyo Flat Panel Televisions
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
I bought a Sanyo DP46849, lcd tv, 1080. and I'm getting a fuzzy picture. It helps when i put my cable receiver on hd channels, but even my blu-ray looks better on my 720 plasma???? any suggestions, I...
I gather from the information given that you are getting the proper signal from the cable receiver but there may be a settings issue with the LCD TV. If the 720 plasma is giving good performance then it has to be settings on the lcd .
I would review the instruction manual to see if you have over look something that is a proper cable select ( hdmi or vga).
If you have selected vga you will not get a clear picture in that mode. HDMI is High definition which works properly with 1080P mode. If you have further issue the manufacturer troubleshooting or Knowledge base will give answers also.
1. check your HDMI cables make sure they are properly seated in the input ports
squarely not at an angle.
2. If you are using a cable receiver check the connection there. Make sure you have the proper cable for your receiver to the TV
3.check channel to see if you TV is selected for channel 3 or 4 as recommend in the instruction manual
4. check the V-chip setup it may be blocking certain channels
5. check you picture modes each channel can have desire picture setup modes.
6. If you are using rca cables you may not get the proper picture as you would with HDMI cable that are specially designed for High Definition TV
Mar 13, 2010 | Sanyo DP46849 46 in. HDTV
How to do a manual channel tune on a Samsung 933HD TV
Nov 01, 2009 | Flat Panel Televisions
Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
May 20, 2009 | Sanyo DP26648-R 26 in. LCD TV
You can only get the freeview / digital channels through cable by subscribing to a package which includes them. They will then supply the necessary decoder to get the channels. Otherwise you will need a digital aerial and a freeview box if you tv is not dtv ready.
Jan 03, 2009 | Flat Panel Televisions
Red screens cause flickering
if normal tv is fine then ,likely the signal from the box is too hot.
if using composite switch to cable ch 3 or vice versa,
or use hdmi cable or change the box .
Apr 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sanyo DP26746 26 in. LCD Television Logo
19 people viewed this question
Top Sanyo Flat Panel Televisions Experts
Are you a Sanyo Flat Panel Television Expert? Answer questions, earn points and help others
