Question about Smeg S1100MFX5 Electric Single Oven
Smeg SA995XR Oven
We are renting a house with a Smeg SA995XR 90 cm electric oven and want to know what all the pictures/icons near the buttons mean and how to set the time on the panel near the buttons and pictures. Because we were left with no instructions from the house owner and we have never had/used smeg before so we don't know
  • 109 Answers
Hello, I know this was a while ago when it was posted. But do you still need a manual? I can email you one if so!
Posted on Jun 16, 2009
I can' t work out what the symbols all mean. I have moved into another house and there is no instruction manual. The oven seems very hot. For example what do I bake a cake on?
Cheers,
Pat
Posted on Jul 03, 2009
SOURCE:
Smeg FU65-5 Oven temperature & timer & function knob lights not turning on and oven does not heat up but the fan comes on.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Dec 02, 2012 | Smeg 24 in 60 cm Stainless Steel Electric...
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Oven not heating up properly
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jul 09, 2010 | Smeg 24 in 60 cm Stainless Steel Electric...
Dials of our smeg oven have rubbed off
You need to disclose the model for any help.
Mar 06, 2017 | Smeg Ovens
Hello. I have a smeg stainless steel oven in my rented house. I have a problem IN KNOWING of what tempertaure I should use for making cakes. Canadian would be 350F.Many thanks. Leila
350 is a good starting point. Some cakes require different temperatures. May I suggest that you read "The Cake Bible" for excellent instructions on temperature.
Sep 29, 2009 | Smeg SE210X/1 Stainless Steel Electric...
Symbols have rubbed off for the Smeg SA708 oven
I Have The Same Problem Have You Managed To Work Yours Out??
Aug 31, 2009 | Smeg S1100MFX5 Electric Single Oven
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
SMEG SA 398X
OK I have just moved into an apartment with this model (SA 398 X/1) and was searching for a user guide (no luck yet).
Anyhow my apartment was owned by a bachelor and it looks as though he hardly used the oven so everything's still intact.
I'm in Australia and these numbers are in Celsius so I hope they work for you.
From top Right (starting at the 2 o'clock position) the four numbers going clockwise downwards are:
50
90
120
160
Then from the left side (starting at 7 o'clock position) going clockwise upwards:
200
230
250 - with dots arching above the 250
Hope this helps -
Jane
Jul 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
What do all the icons mean?
Go to the enclosed link for getting your user. Good luck! http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Sep 04, 2007 | Smeg S1100MFX5 Electric Single Oven
Smeg S1100MFX5 Electric Single Oven Logo
1,210 people viewed this question
Top Smeg Ovens Experts
Jason Harris
Jason Harris
svoorhees
Level 1 Expert
Are you a Smeg Oven Expert? Answer questions, earn points and help others
