Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
PEAVEY GUITAR AMP RENOWM 400
It making noise so loud , when i turn swich on.
    Genius:
  • 1,139 Answers
What type of noise is it making? If it sounds like a load hum, you may have a 60 cycle hum issue. This is caused by a capacitor not filtering out the 60 cycle ripple on the DC voltage supplied by the power supply. If you have this problem I would suggest measuring the power supply with a DC voltmeter first and writing this measurement down. Then I would suggest you plugging the amp into an isolation transformer and taking an oscilloscope (plugged into the wall)and measuring the DC voltage while the oscilloscope is set to AC if you see an AC ripple voltage higher then .1mv you have a bad filter capacitor or a bad voltage regulator.
Posted on Sep 10, 2007
SOURCE:
I have a peavey VIP2 amp.Can I use my acoustic/electric guitar in the electric guitar setting
You can not only play it on electric guitar setting, you can play it LOUD. Its all about what YOU do and what YOU like. Dont accept it when somebody tells you that the music you're playing doesnt sound good to them. ITS YOUR MUSIC !
Do whatever you want. And NO it wont hurt guitar or amp. Rock on or whatever it is you do.
Oct 26, 2015 | Peavey Vypyr VIP 2 40W Modeling Combo...
Peavey problems
Numerous possible issues with your description. I would start with the tubes, and check if not one or more has faulted.
Jul 19, 2014 | Peavey Valveking 112 - Tube Guitar...
How to fix a gt5 peavey rockmaster amplifier
Hi. My name is Danielle and I have a peavey rockmaster GT-5 guitar mini amp, and it can work with/without the cable. I lost the cable and I didn't need to worry because the amp still worked as long as it had good batteries. But, after about 4 months of no use of it, I put in a brand new battery and the light wouldn't turn on. I looked all over the amp to see if something was missing but I found nothing. I'm really not sure what to do because this is a very good amp and I'd hate to throw it away. Can anyone Help Me?
Mar 24, 2012 | Peavey Electronics Peavey Rockmaster...
I have a peavey Renown 400 model 212 without speakers. What speakers should I install to replace the missing ones?
THe speakers should be a good quality and rated jointly at 1.5 times the power of the amp.
Nov 15, 2009 | Audio Players & Recorders
My amp and cable are working... but my guitar wont make sound... when i turn up the amp it makes white noise... HELP!!!
PLUG YOUR LEAD INTO AMP TURN UP JUST A LITTLE SEE IF IT BUZZES WHEN YOU TOUCH THE END OF YOUR CABLE.IF IT BUZZES THEN THE FAULT IS IN YOUR GUITAR MOST LIKELY THE ACTIVE WIRE HAS COME OFF THE INTERNAL GUITAR PLUG.
Nov 04, 2009 | Peavey Music
Hi- When I plug in my les paul into my new peavey windsor class A amp, I get a loud hummimg noise. But when I mute the fretboard or touch anything metal on the guitar, it goes away. I don't have this...
Sounds Like The Amp Has A Grounding Problem Check To See If The Ground Wire Is Hooked Up Inside The Amp And Or If The Pin Has Been Broken Off The End Of The Cord.
Sincerely,
Michael Scott
Jul 24, 2009 | Music
Hi, Peavey Classic Guitar amp , Has NO SOUND
Hi Mike,
If you switch on the amplifier, do you hear nothing at all?
Or do you hear low level noise or hum out of the speaker?
Don't know if you're technician.
If the tubes are glowing, you can measure the high voltage.
Check also fuse 3 and 4, thats the neg. voltage -27V and -14V.
regards,
Gerard
Jul 06, 2009 | Peavey Audio Players & Recorders
My amp won't play distortion.
Hello all you have to do is turn your master volume down to just barley on then turn your pre amp volume somwhere about 2:oclock depending on how much distortion you want ajust your volume on your guitar a little past halfway to give yourself some headroom in case you need to turn up some while you are playing! just think of it as your guitar is your first pre-amp then your amp is second preamp in line ,that is your over drive ,then the master volume is how loud you want the overall volume i hope this help's ya!
Dec 26, 2008 | Peavey Audio Players & Recorders
Peavey banit 65 guitar amp. When turned on it makes a loud almost feedback sound with out anything pluged into it.
A few things can cause it. Bad ground\bad power supply filter capacitor\bad low level op amp IC. You most likely have a bad power supply or trouble at your input jack. Good luck!
barneyluc
Oct 09, 2008 | Audio Players & Recorders
Open Questions:
Car Audio & Video Logo
262 people viewed this question
Top Peavey Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
