Question about Belling XOU252 Electric Single Oven
Operating Instructions Need to know basic instructions for oven clock / timer settings description of mode setting knob etc
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Posted on Sep 14, 2007
SOURCE: Instruction Manual Needed?
Hold cook time button and stop time button together and while both buttons pressed in, use + and - buttons to set time.
regards Paul.
Posted on May 23, 2008
  • 32 Answers
SOURCE: trying to set oven timer
Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
Posted on Feb 19, 2009
  • 377 Answers
SOURCE: Chef Oven instructions
may i know what exactly the model # that you have??
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: belling builtin electric cooker formula multifunction double oven think 488BH no instruction book dont know how to use the timer and different parts of fanoven etc.
get manual here
good for 60 days only
Posted on Mar 29, 2010
  • 250 Answers
SOURCE: Moved to house with a Simpson Neptune oven (analogue clock)
Try this. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Posted on Jul 31, 2010
0 characters
1 Points
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
I have an old electric oven. Somehow after touching the timer settings the oven will now not work. What do I need to set the timer options to. The timer is adjusted using knobs - one for the clock and...
The timer must be in manual mode for the oven to work. Turn the oven ON. With the oven turned on make adjustments to the two knobs. These are generally stop/start timers. These turn and you can also normally press them in. Be patient. When the oven indicator light comes on it will be fixed.
Mar 02, 2011 | Ovens
We cannot get the oven to work and there is no operating instructions available - can you let us know how to put the fan oven on, apparently it has got something to do with the timer?
The clock has to be set with a time. Any time. When you set the time you will hear a relay operate which will switch the power through to the oven controls. If the clock is faulty so that you cannot set a time, you will not be able to make the bottom oven work.
Look at some of my earlier solutions to see how the clock/timer should be set.
Jan 26, 2011 | Stoves 720EF Electric Double Oven
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
My oven is locked out and I cannot get it to work
Is the digital clock/timer set correctly? Sometimes after a powercut I have to reset this to get the oven controls back into manual mode. Follow this link to the user guide for your oven and have a read. Re set the timer and should be ok....hopefully!
May 08, 2010 | AEG B1180-4 Electric Single Oven
I purchased the oven but there were no instructions with it. I plugged it in but I do not know how to set the clock or timer etc. Please HELP
Most Manufacturers have manual online. Look for the model number on the inside door or frame and go the manufacturers website. Look for "Use and Care Manual"
May 06, 2010 | Ovens
I have a older Frigidaire oven model #RG74BC. I have messed with the timer knobs and the oven will not come on. Does anyone know what setting the knobs need to be on to fix this problem
You have probably inadvertantly put the oven into Automatic cook mode, where the oven will not come on until a preset time.
Try pressing/turning the clock/timer buttons and resetting the clock and this should put the oven back into Manual cook mode and you should be ok.
Jan 10, 2010 | Ovens
Clock flashing OOO continously
My son came along and managed to get the clock operating once more by just pressing one of the buttons and turning the knob to set the time. Many thanks for your contact. It was much appreciated. I shall know what to do in case this ever happens again.
Regards, Mary Yorkston
Aug 29, 2009 | Neff B1421 Electric Single Oven
Cant fix the clock to work without the timer
if you are having trouble setting the clock times etc this is probably down to a worn bit generator this is the knob you turn to set the time they get dirty when using oven or grill and wont operate properly,the clock will need changing im afraid as there no way to open the clock without destroying it.
hope this helps
Jul 09, 2009 | Neff B1421 Electric Single Oven
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Belling XOU252 Electric Single Oven Logo
191 people viewed this question
Top Belling Ovens Experts
Chris Hall
Chris Hall
Are you a Belling Oven Expert? Answer questions, earn points and help others
