Starts up ok, very slow to load up, some time curser freezes, it may take 1/2 hour to 1 hour before I can use it. I have used restore dick to restall, it is faster once it stats up but it has same problem when starting, if I let the battery run out without charging and let the machine turn off this way the machine starts up with out freezing. Can you help?
diconnect the battrey boot then put it back this problem is caused by the new acer's battery they call it smart but it's not compatible so after boot in the hardware manager disable the battery and the problem is fixed (i try itt with my aspire 3000)
When you start up, is it using the ac adapter or running off the battery? Either way, 1/2 hour to boot is too long. I would have to say you have a possibility of a memory modules or hard drive going bad or not seated correctly, or a virus like problem, in which case doing a re-install would not repair the situation unless you did a complete clean install and not a repair. Can you provide more info in that regard? Thanks,
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 3000 PC Notebook
My acer 3000 wont come on, but when i plug it in, and press the power button, the battery light...
(More)
My acer 3000 wont come on, but when i plug it in, and press the power button, the battery light blinks 8 X's then it just does nothing
at start up message appears re consistency disc and fat32 file. appears to boot normally except that...
(More)
AT START UP MESSAGE APPEARS RE CONSISTENCY DISC AND FAT32 FILE. APPEARS TO BOOT NORMALLY EXCEPT THAT THE DESK TOP IS DIFFERENT 'ACER BACKGROUND' AND THE CURSOR IS FROZEN. CANNOT SWITCH OFF AT THE POWER BUTTON. HAVE TO DISCONNECT POWER AND BATTERY.
When I open Internet - it will show modem operating, then it will say not operating and it...
(More)
When I open Internet - it will show modem operating, then it will say not operating and it continually goes up and down and internet is running slow when up. I called our Inet service company and went through all the checks and they said it's probably a program issue with the Acer E management program ???
