Question about Dryers
G E dryer
My dryer started making a loud squeaking noise and my clothes were getting caught in the top of it at the front. now the dryer stopped working all together well if u turn on the timer it does heat up but the tub does nothing please help!
  • 1 more comment
  • Anonymous Jul 30, 2008
    a load squeke in front drum and drum is loose
  • reb bob Jul 30, 2008
    a loud sqeake in front drum and drum has lots of play
  • Anonymous Mar 28, 2014
    dryer makes a rubbing noise while the tub is turning
Check the drum slides, they are bushings that make sure the dryer has thrust but not too much. If they wear out the drum has too much movement back and forth and clothes will get caught in between the drum and the dyer housing, and might not turn if its get caught at a funny angle inside the housing.
Posted on Dec 30, 2007
Check the belt, it might be time to change.
VAL
Posted on Dec 07, 2007
  • 641 Answers
Open the service panel and look for a broken belt and does the motor spins. Let me know if you will need for further assistance. Good luck!
Posted on Sep 08, 2007
SOURCE:
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My dryer GE Electric dryer model DBSR453EBOWW squeaks !!
It could be the drum bearing.You prob need to re-grease it.but it could be a devil to get at.
Jun 22, 2012 | GE DBSR453EBWW Electric Dryer
My dryer is making a loud squeaking noise when it
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Dec 27, 2009 | Dryers
Loud squeaking noise
it sounds like your roller bearings are bad you need to get the top open then take the front off loosen the belt take out the tumbler try to squirt oil on the shaft the rollers are on there should be two of them,put it back together and try it,if that doesn't work replace them.
Dec 21, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
My dryer makes a scraping noise when the bowl
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
You may have two problems:
1...The felt seal around the door is faulty,broken, or out of place.This will cause the problem of zippers,buttons, etc. to get caught between the door and the drum
2...Drum rollers, this causes squeaks,and thump type of noises.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication and the felt seal between the door and drum maybe faulty.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt,and felt seal.
Check your felt seal at this time to see if you can reinstall it or you may have to replace it.
Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise and the problem of getting clothes caught in between the door and drum.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 29, 2009 | Frigidaire Dryers
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Loud Grinding noise in Dryer
I know this prob is old, but I had the very same prob with my dryer (very loud squeaking noise). The prob was that there was a screw stuck between the rotating part and the stationary part. Meaning - look inside the dryer (main area - where the clothes go) and rotate it by hand. You may hear and see something causing the friction. Gerard
Dec 29, 2008 | GE DSXH47EGWW Electric Dryer
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Dryers Logo
611 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
