Have replaced plugs and wires car has a hard time starting after it sits for over an hour. Idles rough but runs fine. Is it possible for one cylinder do be bad on the electronic ignition. When i pulled the wire from the ignition on 6 inside was dull looking almost corroded compared to the other 5. I did pull the plug out and crank and it was firing .
V6 sohc 1999 4 wheel drive 95,000 miles
Thank you
ENGINE MISFIRE
There are few possibilities that can cause engine misfire
issues. It can be issue with spark plugs or faulty spark plugs. Also get the
compression test done for cylinders. If any of cylinder shows low compression
then required, then that particular cylinder will cause misfire.
Also get obd codes scanned, the error code will let you know
which cylinder is misfiring or all cylinders are misfiring.
For your trouble shooting I suggest you to refer the help
oinks below. It has step by step details for many engine misfire issues.
Click the link below:-----
Ford Explorer Cylinder Misfire?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-cylinder-misfire.html
Engine Misfire codes on Chevrolet Malibu?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Cylinder 6 Misfire?
http://howtobyme.blogspot.com/2011/12/cylinder-6-misfire.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Ford Explorer 5.0L: Engine Miss?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-50l-engine-miss.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
Can cylinder misfire Damage the Catalytic converter?
http://schematicsdiagram.blogspot.in/2012/02/can-cylinder-misfire-damage-catalytic.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Chevrolet K1500 No spark, random misfire
http://repairhelpcenter.blogspot.com/2012/11/chevrolet-k1500-no-sparkrandom-misfire.html
2004 Ford F150: Engine Misfire and Lean Code?
http://whatisbyme.blogspot.in/2012/05/2004-ford-f150-engine-misfire-and-lean.html
1995 Toyota LS: Misfire at idle or low RPM
http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Toyota Corolla:
Random Misfire?
http://technoanswers.blogspot.in/2012/04/toyota-corolla-random-misfire.html
2006 Ford Freestar: Misfire on Cylinder Number 2?
http://whatisbyme.blogspot.in/2012/06/2006-ford-freestar-misfire-on-cylinder.html
This will help.
Thanks.
How to Increase gas mileage?
http://schematicsdiagram.blogspot.com/2011/12/how-to-increase-gas-mileage-on-2011.html---------
For
car not changing gears it can be shifter assembly issue, or it can also be
transmission issue. Get the shifter assembly inspected with ignition OFF.
For
more troubleshooting, I suggest you to get the Following help link checked, its
complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition coil or
injectors getting cracked or dirty and needs to be cleaned.
To
confirm the problem, the basic troubleshooting is required.
From
start to end troubleshooting these problems I suggest you
to check the help link below and follow its procedure: -----
Mostly all types
of car no start problems are discussed here with solutions.
CAR NO START: ENGINE NOT TURNING
OVER:
http://alltypesofpartsreplacing.blogspot.com/2012/11/car-no-start-engine-not-turning-over.html
ENGINE MISFIRE
Cylinder 6 Misfire?
Toyota Corolla:
Random Misfire?
This will help.
Thanks.
Cylinder 6 Misfire?
Toyota Corolla:
Random Misfire?
This will help.
Thanks.
get the compression test done for cylinders. If any of cylinder shows low
compression then required, then that particular cylinder will cause misfire.
Cylinder 6 Misfire?
Toyota Corolla:
Random Misfire?
This will help.
Thanks.
There are few possibilities that can cause engine misfire issues.
Cylinder 6 Misfire?
Toyota Corolla:
Random Misfire?
This will help.
Thanks.
I have a similar problem that keeps recurring. I have over 190,000 on my explorer and have had the #6 plug replaced, then the ignition coil replaced and most recently 2 fuel injectors replaced and the problem is again returning. It starts as a miss upon initial cranking in the morning and will after about a week start to develop a miss while running. All these problems have started in the last few months. The miss gets increasingly worse after about a week.
