Question about Panasonic SC-HT820V System
No sound for regular tv channels
Can you guys PLEASE help me out. I have a Hitachi 51uwx20b TV and a Panasonic SC-HT820V DVD/VHS combo and I can't get the sound from my TV to play through the theater systems. If it makes a difference, I also have a cable box for that gets hd channels. Thanks So Much
  • kmahaffy Sep 08, 2007
    Thanks!! I'll try that! I like the idea of disconnecting everything and then going to bed. It's not so much excitement of seeing all running right, as it is the frustration of it not. Thanks Again
    Sergeant:
  • 358 Answers
You may need to connect an AV cable from the Audio out L & R a the back of your tv..into your Audio L&R input sockets of your hometheatre unit. OR you may need to setup the TV channels in your home theatre unit using its remote control to do so, with your TV set to AV1 or AV2 or AV3 depending on how you have the cables connected. Sometimes its just amatter of disconnecting all cables in your particular installation ....going to bed...then restarting the cable connection proceedure shown in your manual with a refreshed mind.....its so easy to make cable connection errors when one is excited about getting the desired entertainment hit by having it all running ok eh? Hope this helps - hattonhall
Posted on Sep 08, 2007
SOURCE:
No picture on tv when playing dvd or video
does it have a picture for regular TV watching .if so then the dvd player has gone bad
Nov 22, 2015 | Panasonic Pv-d734s Dvd Vhs Player Combo...
I have a apex tv and a dvd/vhs recorder, with a cable from wall only, how do I install
If you wish to record (VHS) off cable :
First connect the co-ax cable from the wall to the input on the DVD/VHS , then connect a second from the output of the DVD/VHS to the input of the TV.
You will need to match the channel (3/4) output and input. There should be a switch on the back of the DVD/VHS.
Tune the TV to channel 3 or 4 to match, To watch DVD/VHS .
Channel selection will be with the DVD/VHS when it is powered on.
TV will tune to channel when the DVD/VHS is off.
Jul 06, 2012 | Televison & Video
Don't know how to copy video to DVD
blank disk to dvd tray....VHS in deck....PUSH PLAY ON VHS...and RECORD on DVD BURNER....if it is a burner...they weren't all burners....it has to say DVD WRITABLE or some thing in that mannern
May 10, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
No picture when connecting CRT TV to Panasonic DVD/VHS Combo
If you combo get activated the progresive scan function you never see the videio only sound you need to deactivate
Feb 14, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
1/2 Grey Screen when switched to DVD and VHS
First of all,i don't know if you have a combo dvd/VCR player or two separate units.Secondly,please tell me how you connect your dvd/VCR combo OR DVD player and VCR player to your TV.
Solutiondoct
Oct 22, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Recording VHS from TV/VCR combo onto DVD
This machine does not support DVD recording. Are you trying to make a tape from a DVD, by some chance?...accordianman
Jan 21, 2008 | Panasonic DMRES15 DVD Recorder
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Panasonic SC-HT820V System Logo
177 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
