Kitchen Ranges Logo
Posted on Sep 08, 2007
No heat Maytag smoothtop range MERH752BAB
After working well for about a week our Maytag Performa Electric Smoothtop Range (Model #MERH752BAB) has no heat to the burners or oven. The "on indicator" light does not turn on. Only the clock and control panel buttons are working. It does not seem to be set to any delayed or Sabbath settings. Our first problems with the heat turning off seemed to be fixed by tipping and resetting the range. Now nothing works. Any suggestions? Many thanks!
  • 1 more comment
  • Anonymous Mar 12, 2014
    whirpool wge32300 electric range/oven - all stopped working at the same time, I took the back off and I can't find a thermal fuse, and the reset button doesn't seem to want to 'reset'
  • Anonymous Mar 21, 2014
    maytag performa electric range indicator light wont go off even when stove is not hot
  • Anonymous Mar 27, 2014
    When we turn the oven on a small red light goes on. But there does not seem to be a way to determine when the oven reaches the set temperature. The red light stays on as long as the oven is turned on. And yes, there is no thermometer with the range.
A
Anonymous
Thanks for replying -- I didn't get into the full details but although it had not been used it was no longer under warranty as we bought the house (with new appliances) from an owner who had fixed it up and remodeled the kitchen but never lived in it (or used the stove). The previous owner did however give us a sort of warranty on the house and so we got in touch with them. We got a repairman in and it turned out the the power cord was badly damaged on the underside of one of the three parts and that was why we had power to the clock and control panel but not to the oven or range. In the end we were happy that it hadn't started a fire back behind the stove.
A
Anonymous
It would have to be under warranty if this happened after only 1 week. I would contact the manufacturer.
Maytag precision touch control 800 electric slide-in smoothtop: the Inner element of triple burner stopped working. How to fix it?
The first step to fixing the inner element of a Maytag Precision Touch Control 800 Electric Slide-In Smoothtop is to check the power supply for the range. Make sure all connections are secure and that the outlet is working properly. If the power supply is fine, then you may need to replace the inner element on your range. It would be advisable to consult the manual
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
reviews.us-appliance.com/.../MET8776BS-Maytag-Gemini-Smoothtop-D...
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Where to purchase
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More
Recommended electric smoothtop ranges
Electric smoothtop range Ratings
Electric induction ranges (9)
Recommended electric induction ranges
Electric induction range Ratings
Electric coil ranges (10)
Recommended electric coil ranges
Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More
Recommended gas ranges
Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More
Recommended pro-style ranges
Pro-style range Ratings
Jul 19, 2015 • Ovens
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 • Cooktops
1helpful
Indicator light on my maytag electric smoothtop range will not shut off even though the indicators are off?
One of the high heat sensors has failed on one of the burners under the glass. Disconnect one sensor at a time to find out which one, then replace that burner assembly.
I have a 2 year old smoothtop GE stove. I was
that clicking usually means that the erc is trying to turn on the burners,
i would unplug the range
pull it out and check all the connections of the bake element
Oven will not shut off
Sounds like a stuck relay in the control board. The only way to repair this problem is going to be by replacing the control board. If you have anymore questions please ask. I'll be more than happy to help you further.
Thanks
Maytag smoothtop kitchen range
The only way to find out for sure is to check the voltage to the element.
Most of the ranges have 2 or 3 screws under the front of the top. Remove them and the top will tilt up. Be careful, there is voltage on some of the wires.
Turn the switch on and check for voltage across the element terminals. If you have 240V, then the switch is ok and you probably need an element.
If you can post the complete model number from the tag on the back of the console, I may be able to give a little better directions.
Thanks/Mike
Where is the model number on my Range?
As you are facing the range, there should be a metal plate (held on by one screw) on the left hand side behind the console. Model and serial number should be located here. On some models the information will be along one side of the oven door opening, or bottom drawer. Hope this helps you.
Top Kitchen Ranges Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
john h
Are you a Kitchen Range Expert? Answer questions, earn points and help others
