Question about Pioneer DVR-330 DVD Recorder
Caanot play CD-R/DVD-R burnt from PC
I have a Pioneer DVR-330-S and I am unable to view images that I have burnt onto disc from my pc. I am also having the same problem on other dvds. The pictures are saved as jpeg files.
    Sergeant:
  • 349 Answers
First check that in your user manual that the dvd player is JPEG compatible. When you say you are having the problem on other DVD's do you mean when you use DVD+R and DVD-R disks on your own player or that yu have tried to play the same DVD disk on other brand DVD players without success? You dont mention which software you are using to save your JPEG's to Disk or whether you can in fact view them on your PC. After making sure that your Windows media player displays your pictures ok, Try using the NERO dvd burning Rom programme to load your JPEG's. I am assuming that you are not trying to record a DVD in a CD burning drive? hope this helps - hattonhall
Posted on Sep 08, 2007
Hi, I have a DVD PIONEER DVR-330-S writer. Here is the problem: it starts writing disks, but can't finish the job, hence the disks can't be read by any DVD player. Could you please help me...
After you have burned the disc it will require Finalizing.
This is done by the same machine.
Consult the manual for specific insrtuctions.
Al
Feb 07, 2011 | Pioneer DVR-330 DVD Recorder
I have an Hp laptop with a pioneer dvdrw dvr k17b not burning.
dies your burned this work on your PC? if it works on your pc you just have to select the correct settings for your burning software, when you burn does it ask you to burn multiple sessions? if it does and you selected the option create multiple session then what will happen is the disc's you burnt will only work on your windows and not on any other computer or devices that use dvd's or cd's, on the options it will also have a choice for you to choose single session only wherein this will allow you to use the burnt disc in any other computer and will most likely work 100% of the time ^_^ NOTE: this step I gave all depends on the software you use to burn your disc and you may be required to play around your software for some softwares do not have the same info in them but at time be the same in thier function and purpose ^_^ I just based this answer to your question using my NERO
Jun 06, 2010 | Pioneer DVR-107D DVD±RW Burner
Pioneer dvr 111d unable to write CRrw of heigher speed moserbaer 4x-10x
This could be the actual CD/DVD/DVDDL/RAY disc that you are using, try using an app called imgburn to see the medias fastest speeds.
Jun 02, 2010 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
PIONEER DVD-RW DVR-112D won't burn discs. G4, OS 10.4.11
So the driver is either 'malfunctioning' or it's broken...do you know what revision firmware the drive is using? Your disk authoring software may tell you this. The latest version is 1.22 which you can get by Googling PIONEER DVD-RW DVR-112D firmware. Or go to the Pioneer website. I do not know how to upgrade the firmware for the recorder in MAC Land, in PC Land the firmware update is a simple executable file.
If you are running this version you can try to reflash it. Have you tried another brand of DVD disc? Some discs are less compatible than others. Try another brand of DVD
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/426554181POV_DVR-112D.pdf
Oct 13, 2009 | Pioneer DVR-112D Burner
DVDs burned with Pioneer DVR-110D do not play on the same burner
Are you burning the files with a DVD+R format. Use DVD-R. Not all players will recognize DVD+R. Also, check the region that the movies are made in and see if the player can be switched to that region. Also, are you trying to burn files larger than 700 MB. If you are, in creating an iso image or copy if you are downloading the file you have to match the checksum of the original file to the downloaded one.
Jul 25, 2009 | Pioneer DVR-109 DVD±RW Dual Layer...
PIONEER DVDRW DVR-K17B ATA Device Issue in HP Pavilion DV9500 Lap
you may need to clean the lens of drive with a wet tissu paper, otherwise the drive might gone out of order, need replacement.
Feb 10, 2009 | Pioneer DVR-107D DVD±RW Burner
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Pioneer DVD RW DVR-K17LF
You're creating Disk images on your Hard Disc Drive.
See where your CD Burning Software stores the images of the Disk and use the appropriate option to burn them onto a blank CD.
Goto www.sahajayoga.org to attain your Self realization and find a Sahaja Yoga Center to goto.
Jun 22, 2008 | Computers & Internet
Pioneer DVR-109 DVD±RW...
This ahs to with speed of recording of the CD/DVD try reading CD/DVD burnt at a lower speed like 16x.
Most DVD writers has low maximum reading speed as compared to CD-ROMs.
You can try burning a CD on it and then reading it, if reads then it shows that other cd were burnt at faster speed than it can read.
If it read lower speed CDs then you can just add an additional DVD/CD-ROM just to read faster speed disks.
Mar 24, 2008 | Pioneer DVR-109 (44121479) DVD±RW...
Pioneer DVR-330 DVD Recorder Logo
121 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
