SOURCE: how to use polaroid izone 300 digital camera as webcamera
Look up the manual..you will find it on page 68
The software is on the Cd that comes along with it..
SOURCE: Polaroid Change Battery ?
to answer your question on charging your camera with your pc you can if
you have the drivers installed on your computer it will let it charge
through the usb. as for your second question about being able to
replace your cameras battery: well the answer is that it's not possible
to unless you either send it to the company to replace it should or
when it fails. they will charge you a fee if the camera is out of
warranty or the alternative is basically opening the camera and finding
a similar battery. should you decide to open your camera than this is
the possible solution that i came up with for replacing the battery.
http://www.fixya.com/support/t559753-changing_battery_find
hopefully this helped answer your question.
SOURCE: Users Manuel
hi
try here see if this one helps you Polaroid iZone 300 Digital Camera User's Guide
riz.
SOURCE: where can i download a user manual for a polaroid izone 300
Hi!
You can the manual right HERE!
Cheers,
Pelu.
