Question about Kenmore 43142 Front Load Washer
Loud spin, doesn't fill, dial doesn't move.
I just purchased the Kenmore Front load washer 417.43142200. The dial doesn't turn on its own in regular wash mode or heavy wash load. The dial only moves in perm press mode. And when it doesn't move the machine just keeps doing the same thing over and over... (filling or trying to fill and then draining) When the dial does get to final spin in the perm press mode the whole machine shakes so intensly that the dryer will fall off. Am i supposed to take the cover off of the washer to stack them? Also the washer doesn't fill... it gets the clothes soaking wet but never fills to wash..... HELP ME! Oh... and i never got a owners manual with this product.. Did i buy a piece of junk?
  • 60 Answers
Yes you do have to remove the top off the washer and the washer should come with a mounting kit that must be used when stacking this unit. as far as your filling and draining problem i have had this problem several times before you have to replace your speed control board or sometimes called the speed control unit in the lower right hand corner of your washer
Posted on Sep 09, 2007
SOURCE:
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Our Kenmore Top Load Washer series 800 is not working properly. When you set the Control Cycle knob to start a normal load it agitates instead of filling up with water rinses instead of stopping the load...
We bought our Series 800 Washer (and dryer) in 08/2009. My wife has never been happy with them. It is off warranty now 10/5/2010. We have always had Kenmore... but she hates this set.
We are having the exact same problem with this washer. The current problem is on the regular cycle when it gets to the spin segment it does spin and all the water is removed HOWEVER just before it shut off it fills with rinse water.
I'll bet any money they are made in China. Looking for a solution on the web. Sears is no help.
Jul 03, 2010 | Washing Machines
Kenmore 431423 won't advance cycle, won't agitate
not sure why he would replace the shocks this is clearly a timer/control issue. Replace the main control
Jun 11, 2010 | Kenmore 43142 Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is [email protected] live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore washer fills and spins at the same time
If the washer has been recently moved the drain hose may be too far down the stand pipe causing a siphoning effect
Jun 11, 2008 | Tecnik TKL9260 Front Load Washer
Kenmore 4314220
It sounds like you could have a couple of issues going on here. First of all, to answer the question about stacking the units; there is a mounting kit that you are supposed to use to place the dryer on top of the washer. The top is supposed to come off the washer to accomplish this. There are a couple of brackets to install and the dryer is supposed to mount to the washer with a couple of screws. Your local appliance store should be able to provide this for you. All you need is the model number of the washer and dryer. If the timer is only working on one cycle then you may have a bad timer. But...before we go jumping on that bandwagon...you mentioned that the washer is not filling and the water just keeps running out. This sounds like a problem known as "siphoning". If you have placed your drain hose in the standpipe in a manner that does not provide an air gap for drainage, the washer will not fill and will continue to "siphon" water from the machine as it tries to fill. If the washer cannot fill, the pressure switch will not shut off, and the timer will not advance any further. Double check your drain line to make sure you do not have it shoved too far down in the standpipe (3" to 4" should be sufficient). If the drain hose is sitting in the drain trap where the water sits, there's no air gap. Also, make sure you do not have the top of the standpipe sealed for any reason. Once again, you need an air gap in order for the water to drain properly. Let me know if this helps you.
Sep 08, 2007 | Kenmore 43142 Front Load Washer
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Kenmore 43142 Front Load Washer Logo
101 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
