Question about Sub-Zero 611 / O Bottom Freezer Refrigerator
Sub zrero freezer door stuck
I can't open the freezer door on my sub zero
  • 178 Answers
SOURCE: Sub-Zero model 211
First of all, the freezer temperature is the MAIN part of the unit. Either look for a new thermostat for your model unit and try switching it out, or look for a new fan motor for the freezer. The concept of the refrigerator is just like an A/C unit. It is designed to remove heat from one spot and andcarry it to a discharge place of NO imporatnce. I would definately start with the thermostat in the top of your refrigerator since it is likely the least expensive solution. Research your particular model number for proper fan replacement if it comes down to it. Also, check to insure that the freezer isn't frozen up behind the back wall. Let me know if there is anything else I can help with or if you need more assistance on the same issue.
Posted on Mar 14, 2008
  • 26 Answers
SOURCE: Sub-Zero 550 water dripping on right side of freezer forming ice on draw
Sounds like your freezer drain is blocked up. You will require a freezer drain heater kit for this repair. It was a common problem for this unit and can be a easy fix. However it does take some patience to fish the heater down into the drain pan.
Posted on Mar 31, 2008
  • 7 Answers
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
SOURCE: Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
Posted on Nov 12, 2008
  • 56 Answers
SOURCE: I nee to tighten up the freezer door handle on a
There are different handles depending on serial number. The older of the two is at the top of the door. The screws are covered with a magnetic trim piece. You can remove this by putting tape on the chrome and pull up. You can then tighten the nuber two phillips head screws. The newer model is on the door itself. These are held on with small set screws accessed from the bottom of the handle. You may get by just tightening the set screws. If not you need to remove the handle by removing the set screws. You can then tighten the standoff and reatach the handle. For the 632 same procedure except it will be on the side.
Posted on Apr 23, 2009
  • 37 Answers
SOURCE: Left door open on Sub zero model 650
It went into self protection mode. Just leave it closed and when the compressor cools down enough, it will start. Once the ref starts to cool, the lights and such will come back on.
All of this assumes that no failure was caused by the long run times when the door was open
Posted on Sep 02, 2009
0 characters
1 Points
Closing and opening a sub zero door
Maybe I'm not understanding your question completely.. You can open the doors whenever you want - as often as you like. The doors are no different than any other fridge as far as how often you can open and close them. Please clarify if I missed your intent. Thanks!
Jun 17, 2010 | Sub-Zero 650 / O Bottom Freezer...
My sub zero 642 just starting making a humming
It is your evaporator fan. When the door opens power is cut to the fan motor.
Apr 29, 2010 | Sub-Zero 642
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Ice making for sub zero 48
The sub zero should make ice soon after being installed. If there is ice around the door frame of the freezer there may be a problem with the door frame heaters. There should not be ice around the door frame.
Nov 09, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Sep 02, 2009 | Sub-Zero Bottom Freezer Refrigerator
Cannot reopen Sub-Zero 642 freezer door for 50 seconds
Yes, this is normal.  My 642 does the same thing. It seals to be more efficient while trying to cool back down after it has lost heat while open.
Jun 21, 2009 | Sub-Zero 700TR
Freezer stuck on -20 degrees
well it depends on how long the door was open for during the cleaning, your evap coil was unable to cool the unit due to the warm air coming in, that will cause the evap coil to over frez . un-plugging the unit may work but the best thing to do is force it into a defrost you can do that by pressing and holding the ice key on the key pad for 10 sec or till you hear the freezer shut down this will thaw the ice on the coil and the unit with come back on within 20 to 30 Min's
Jan 04, 2009 | Sub-Zero 650 / O Bottom Freezer...
MY Subzero freezer door is also stuck shut .
This sounds a little high especially since the door can't be opened the check it out. I would call another appliance tech. First, unplug the Ref and let it defrost then plug it back in and send some more info on what it's doing before it gets so bad the door becomes stuck again.
Dec 09, 2008 | Sub-Zero 650 / O Bottom Freezer...
Cannot open the bottom freezer door anymore; it seems stuck
sounds as though the defrost system has failed or the freezer defrost drain is blocked. take off the back panel of the freezer and see if excess ice build up. if so, defrost carefully with a hairdryer. at bottom is a drain. check if blocked with ice and if so melt off with hot water till water flows away freely. if i'm right, appliance will start to work. if fault re-occure then defrost system is at fault
May 06, 2007 | Sub-Zero 611 / O Bottom Freezer...
Refrigerators Logo
562 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ACME Sub Zero...
ACME Sub Zero...
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
