My DG60FA-US8 GAS DRYER HAS NO HEAT. REPLACED COILS DID NOT HELP. ANY HELP WOULD BE GREAT.
For what it's worth: You can eliminate 3/4 of your work if you simply watch what the dryer does. Most have a peep-hole in the lower front covered by a small plastic plate. Remove the plate, start the dryer and look into the hole. If you hear a "click" right as you press the start button and the drum turns, you know the motor, timer and door switch is OK. If you then see a dull glow and a second click, ALL the thermostats, fuse-able links, gas igniter and wiring are OK. If you then see the burner ignite with the blue flame, the flame sensor, valve coils and fan are working fine. If you let it run for some time and then suddenly you only see the dull glow, but no click or blue flame, your gas valve coils are defective. (they will work when cool or cold, but not as they heat up from use) This also will stop the timer from moving since the timer runs when the coils are working well (the power to the timer comes through the coils - just figured this out today). If you don't see the dull glow, the ignition/igniter wire/element could be bad. Hope this helps folks. I see in the forums where one individual just says "Ignition coil" every time a gas dryer has a no-heat issue, but a vast majority of the problems comes from the $20.00 gas valve coils that most anyone can replace.
gas dryer no heat I check the igniter its good I changed the coils on gas valve , I have check the limit switch's all good , I have checked the flame sensor good , the control board makes a small noise sounds like an air leak
Gas ignites but goes out quickly. Already replaced gas coils.
