Question about GE 25951EE2 Phone
Ge 5.8 ghz edge phones
1 phone will display unavailable when trying to make a call,seems fine till calling,2nd phone still working fine
  • Anonymous Feb 22, 2008
    Have the same problem. Says unavailable, however, I only have the one phone and can't change it out.
    Does anyone else have this problem?
I have changed my phones in the bases and it fixed this problem, you also need to make sure it is charged up well. I have problems with the volume even on # 4. Don't you?
Posted on Sep 19, 2007
Handset 2 show unavailable
there is some battery problem with your phone please service it asap.
Jun 21, 2009 | GE 25841GE3 5.8 GHz Twin Cordless...
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
Unavaiable second phone
Placed the second phone on the main base and it seemed to reset and now works fine.
Dec 15, 2008 | GE 25952 Cordless Phone
Cordless Phone
When trying to make a call,messages appears unavailable on both hand sets that i have,i can not receive or send calls, but my land line does.
Oct 05, 2008 | GE 25932 Cordless Phone
GE 25922 5.8 Ghz Gives Unavailable display and static discturbance
My answer:
Not sure why the first part of your Problem was all garbled up unless you were using HTML format??
Unfortunately I can relate totally to your GE cordless 5.8Ghz phone problem all too well.
Pleaseread everything below - even if it sounds unimportant. Once youdo youwill understand everything about cheaply made stuff sold here inthe USAtoday.
Had the very same experience with an almost identicalcordless phonesystem with the same everything features. Only it wascalled anOlympia. The Company is now defunct, as in OUT OF BUSINESS.Guess why?
All these cheap "throw-away" phones are made by thesame China Cooverseas under contract for various companies having USAbased roots.Everyone from AT&T to GE included! I've since boycottedGE for badwashing machine transmissions that were all made in China,and thatthey will not do a RECALL on! Why you ask? Because they don'tcare thatis why! Also boycotted GE for bad refrigerators,as well as SONY for their junk as well. If we just stop buying theseJUNK brands they will go away permanently!
WhenI contacted that Olympia CS Dept 800# theyfirst redirected me to aMOTOROLA "Fulfillment Center" somewhere, andthen to another one linkedto Giant Intl as in, as Iguess they handle complaintsfor all this cheap "branded" Made in Chinajunk we are now stuck with.Remember that name - for if you ever see itanywhere on the next thingyou are buying that is made in China - youmight want to walk away fromit like a bad plague!
Olympia sent me out3 FREE replacement phone set upgrades to replace myinitial bad 2.4Ghzsingle handset phone. Each one they sent me out as aFREE replacementupgrade was worse then the 1st.
The 1st one being a singlehandset with answering machine that had echoproblems and noise feedbackup the kazoo and then the digital displaywent out after only 2 monthsuse.
The 2nd one being a dual handset with answering machine that had the same echo effects and feedback problems.
The3rd one being a 5.8Ghz dual handset system with no answeringmachinethat sounded like a geared motor was running inside the phone,not tomention feedback as well.
After that the CS Dept said I was toast and nothing more could be done.
Sincemy first phone was FREE anyway - I figured what the heck I hadnothingto lose, and so that is why I tried to at least get 1 goodworking phoneout of the 3.
I wound up just stripping down the very 1storiginal 2.4Ghz phone forparts (ie: power adapter, good Ni-MH battpack, etc), and then did thesame with the 1st 2.4Ghz replacementphone set as well as the 3rd5.8Ghz phone set. So I wound up with a lotof nice AC adapters and 4more spare Ni-MH batts, and various other spare parts. I already found uses for 2 of those AC adapters btw!!
Ialso did a little investigating into that 2nd phone set - thatworkedsomewhat OK - and here's what I found out that was wrong withitinside. All I wanted to do is make the BEEP tone a bit louderbyopening up that small pin hole in the case cover. So I removed the2small screws in the batt compartment and carefully pried open the2handset body halves. What I found inside shocked me.
Instead ofthe antenna wire being pointed in the UP direction - so thatit wouldrest inside the handset's antenna nub on top - guess what? Itwas foldeddownwards alongside the IF circuit board thus causingfeedback inducednoise back to the phone base unit. NICE huh?
5-10 seconds and alittle bit of re-bending and VOILA - best receptionI ever had! Did thesame thing with the 2nd handset, as this was thephone system with 2handsets. I also opened up the answering machinebase and re-directedthe top antenna wire more upwards as well, as itwas laying way tooclose to the IF circuit-board as well.
What a difference thismade, and here the Private Label company thatmade them didn't evenrealize their error on what was probably millionsof these cheaply made"throw-away" phones! The other thing I hear thatgoes out on these"branded" cheap phones is the display, such as thatwhich happened on my1st replacement phone. Oh well - what do youexpect for $3?
Reason I say $3 -
Checkthis out below which I found onlineregarding your very same phone set -I know it'll make you cry, butthis is really what you are buyingQUALITY wise. A $3 phone set is all- Nice huh?
Super Hot Deal
1. is carrying this 5.8GHz Cordless Phone System for $59.99
2. During checkout, select in-store pickup option (required forthecoupon) and apply 20% off coupon code "PYAXCA7AG9" on it(Expires09/07/2008)
3. There is a $45 Exclusive Mail-In Rebate on it until 08/31/2008
4. Your Final Price: $59.99 - 20% - $45 = $2.99
Ifyou decide to open up your GE phone yourself and fix it let me knowifyou were successful by posting a reply here, and please do rate myfixhere as I know this is what happened to your phone too!
Aug 31, 2008 | GE 25922 Cordless Phone
GE Model 25952 Series 5.9 GHz Handset Speakerphone
take the phone back to the store and get a new one
Mar 03, 2008 | GE 25952EE1 Cordless Phone
New dual phone "Unavailable"
read the manual,you have to put code from 1st base phone,
i do not remember the code,
Jan 01, 2008 | GE 25932 Cordless Phone
Base set fine - additional handsets dont work
The additional handset and the base need to "pair" first. Put the handset in the base cradle till you see the red light blinking. That's when they are paired.
Nov 07, 2007 | GE 25951EE2 Phone
Whont work, please register in displayed on screen
To solve the register problem.... Put each phone for 20 seconds or so in the main base. I had the same issue, and resolved it this way.
Aug 21, 2007 | GE 25932 Cordless Phone
2nd handset doesn't work
Hi Rayfatz,
I think your problem might be that the second handset is not registered with the base station. Take the second phone out of it's cradle and place it in the base station (where the first phone is), and leave it there for 20 seconds. Place it back in it's own cradle, and it should start working. Hope this helps! Hal
May 27, 2007 | GE 26938GE1 Cordless Phone
GE 25951EE2 Phone Logo
107 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
