Question about Polaroid FLM-3201 Television
No Power to TV
This morning, my tv simply shut off. The light on the front doesn't even turn on. I unplugged the TV & waited, plugged it back in, still dead. I removed back panel, but area where there might be a fuse was not easily accessable. I have owned the TV for over 2 years, do not have extended warranty. What can I do?
    Genius:
  • 1,139 Answers
I would call or contact one of the shops on FixYa and get them to fix it. For this you may need to provide a schematic, what I would suggest doing is contacting the company and asking for the service documentation for the TV and then providing that to whomever you are having fix the device or if you feel comfortable do the work yourself you can use a FixYa Expert to start you on the process of troubleshooting the problem. It sounds like you do have a power supply problem.
Posted on Sep 08, 2007
SOURCE:
Philips LCD TV Turns Off After Being Turned On
Most LCD TV power problems are simply solved by replacing the power supply board.
Oct 07, 2017 | Audio Players & Recorders
No sound, no picture
Hello sorry to hear that. From your description it sounds like your signal board may have been damaged by you plugging in your laptop to it. The signal board is the one with the tuner on it.
Feb 22, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
I have a Toshiba TV model 36A43 that won't power on. The same thing happened yeaterday as this morning. The tv will not power on via remote, or the manual power button. Yesterday, the same thing occurred...
It sounds like you have a switch problem at the front panel of the set. If a switch gets stuck internally the micro is trying to process the command and won't respond to any other commands. The only way to find out is to go into the set and desolder all the manual switches and see if the remote will work the set. It has a seperate detector for the remote. Thanks for using fixya. Good luck
Nov 08, 2009 | Toshiba 36A43 36" TV
2003 Sony Trinitron 36" television. Just shut off, light blinkin
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, Service will be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Sep 14, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
RCA D5210 TV will not turn on...
Common problem on this tv.
Replace capacitors in power supply.
2.2uf 100V and 15uf 100V and 470uf 25V.
Thank you
Aug 04, 2009 | Televison & Video
RCA Scenium 44" HD44LPW62
it does not sound good take it to tv shop intermitten shut down or dead sorry
Apr 03, 2009 | RCA Scenium D34W20 34" TV
Ilo tv isn't working
Try a power drain:
1. Unplug the TV's power cable so that the TV is not grounded to the house.  Do not simply turn off a powerbar if one is in use. 2. Press and HOLD the TV's own power button for one minute to drain the capacitors. 3. Plug the TV back into a wall outlet versus a powerbar, if one is in use and see if this makes a difference.
If the TV still won't turn on but you have a LED light flashing, the problem is usually with the TV's mainboard and not the power supply or the LED wouldn't even be on.  Service is likely required.
Mar 24, 2009 | Televison & Video
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Won't power up
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Sep 17, 2007 | Hitachi 60UX58K 61 in. Rear Projection...
Polaroid FLM-3201 Television Logo
60 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
