Watches Logo
A
Anonymous Posted on Aug 22, 2013
Where can I find a burberry watch band replacement for item BU7505
2answers
Nautica band links
NAUTICA REPLACMENT BAND http://www.ebay.com/sch/bluss_929/m.html?item=221597748969&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
How to reset my Burberry watch BU1205
To reset the time you pull the middle dial out a bit and twist it around to get to your desired hours and minutes. To reset the chronometer you need to press the start button until it stops and then the other button, known as a reset button.
1helpful
Point zero manual
pull crown out to second position then press start button till it goes to 12.00 then push crown back in ....job done......
1helpful
How do I remove the back of this watch?
I have seen other burberry watches and the back should pop out .
1- Locate a very small tab or recessed area on the edge of the back cover 2- Pull out the stem, which releases the back on some watches.3- Get a small flathead screwdriver it needs to be a thin inflexible tip 3- Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). 4- When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch. This information is on wiki: http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools
2answers
1helpful
4answers
I want to buy wristband for my nautica n 135 30
This is a proprietary fit band. Only the manufacturer carries the band. You will want to contact Nautica's watch department customer service directly at:
[email protected]
Nautica watches are produced by Timex, so this is the correct email.
Specify the model number, serial number, band number (if you see one on the reverse) and request price and availability for the band.
If the band is not available, they may be willing to offer you a new watch as replacement.
5helpful
My 433lsl black band broke. I can not find a replacement broke
order a replacement band directly from skagen its only $25
http://www.skagen.com/service/home.fx
Top Burberry Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Burberry Watch Expert? Answer questions, earn points and help others
