Question about System Power Supplies
Ignition problem I have a 1983 Kawasaki Spectre 1100. The bike was running last night. Today, I have no spark or power to the coils. I have spent the last three months rebuilding this bike and to come this far and now it won't run,I'm a little frustrated.
0 characters
1 Points
I have an Antec external hard drive. Earlier today it was working fine but now it won't run at all. The light on the plug-in is green but there's no "whirring" sound like it usually has and the computer...
the fact that it is not working on two machines suggests it may have become faulty. If the lead between machines is a separate one (usb to drive connection) try using another one to make the connection. Leads do not last forever either.
Nov 01, 2013 | Antec System Power Supplies
Hearing a buzzing sound at start up.
I think that your PSU is dead and your motherboard must be dead too (not sure)
Dec 16, 2012 | System Power Supplies
I bought an Acer netbook last week. Love it. Today, I am in Germany and it will not charge. I have an adaptor, but the charge light on the netbook does not come on at all. It boots up fine from the...
Most power adapters are able to run the Euro 220v @50/60hz but make sure. The "Input" side should say 110-240V and 50/60hz if it says only 110v and 60hz then you power supply will not work in Germany. Also check to see if the "output" on your power cord is the same as what is your laptop is. I have mixed up power adapters before and it will simply not work. If you try and plug it in it will fry it. If you have to grab a new power adapter the best store i can think of is a place called Saturn Electronik kinda like Germany's Best Buy. It has a hazard orange sign most times.
May 09, 2011 | Acer (56.04145.901) (5604145901) Power...
Dear sir last night i on my persinal computer . just i power on my pc power supply was short
Sounds like your Power Supply Unit maybe failing, check stores or online for a new 1..
Aug 28, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Dimension 1100 not booting. In Boot sequence screen, says "Hard drive not installed"
Your hard drive is probably toast and needs to be replaced and Windows reloaded.
Make sure to check your BIOS settings first and make sure the drive is showing up in there and it's not deactivated.
Sep 10, 2009 | Dell Dimension 1100 power supply ** FREE...
Hi, sinds a few days, the battery of my acer travelmate 6292 does not work well. The battery could last more than 3hours and sinds last week it is down after 40 minutes. What's happening ?
well they are 2 problems u have
first like everything if u use ur pc all the time on battery it will wear out,,,,like any other rechargeable battery ,,,,,and if u not charge the battery every night.....u will have not enough power left
also if u did not use the battery on the start when u got ur pc it will wear it not get used and not get recharged....sounds silly but i had the problem with mine......with not using battery power.....
if the battery not get better u better look for a replacment......not cheap......
Jul 03, 2009 | System Power Supplies
Gateway laptop no power. Working ok last night checked power supply pack all ok 19v coming through But wont power laptop help
Remove the battery and try to power it. if this fail, them change the memory and then the processor if this also fail then one of the power chips on board is bad (also check the power connector if is not soldered properly.
Jul 01, 2009 | System Power Supplies
Computer will not turn on
Best way to check is to open your case. Near the power supply plug to the motherboard should be a little led light. If it is getting power to the board this light should be green. If it's unlit then most likely your power supply has gone bad. Hope this helps.
Dec 21, 2008 | E-Machines Emachine T5026 power supply **...
Loud fan and wont turn on
power supply is probably shot and you are feeding a voltage way over what is needed. I have a dell that refused to operate one day. I went to www dot affordablesurplus dot com and found a 350 watt power supply with all the RIGHT plugs. Never had a problem since.
Dec 04, 2007 | Dell Dimension 8400 power supply ** FREE...
Idle problems
Hmmm... this doesn't sound like a problem that belongs here... By "cuts off" do you mean stop running, or misfire? Carb. problems often are the result of the bike having set for many months or a year or two with old gas, which can result in a varnishing like of the fuel in the carburetors, which can clogg small passage ways, and subsequent no-idle, or other poor fuel delivery. Problems such as this require repair by knowledgeable mechanics. Other things which can upset correct fuel/air mixture are modifications such different exhaust system, air cleaner change, camshaft- any mod of these can require some retuning.
Aug 31, 2007 | System Power Supplies
System Power Supplies Logo
32 people viewed this question
Top System Power Supplies Experts
Brian Sullivan
Brian Sullivan
Are you a System Power Supply Expert? Answer questions, earn points and help others
