Question about Amana ACD2234HRS Side by Side Refrigerator
Light on but not cold
By reading the online help it seems I need to reset the pressure switch where is it located?
  • fillibuster Sep 08, 2007
    We have not defrosted recently and the back is not really warm....not like usually. I took the pan off of the back, very bottom of the door and the fan seems to be running somewhat. I will be home this afternoon and will need options...pretty much everything is spoiled by then, but not much I can do about it.d
    Thought I replied...but have not recieved a response. Again...we have not defrosted the fridge..ever, the fridge isn't even three years old, the back is not warm, the light is on, the fan in the back runs but there is no cool air.
  • 944 Answers
We could use a few more details to identify the problem. Does the fridge turn on fine and run (is there a noise at the back?) Does the back get warm at all? Have you defrosted it recently? most similar fridges do not have a resettable "pressure switch". some have a resettable thermal cutout on the compressor, usually on the side. unplug the fridge from power before rooting around the compressor area. Hope this helps - awaiting more info :)
Posted on Sep 08, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Sep 13, 2007
    If the compressor is running, but the back is not getting hot then you either need to defrost completely (ice crystals can form in the gas system and block it) or you need more gas and a leak check.
    If the compressor is not running, then there is either no gas and a safety cutout has operated which cannot be reset without adding more gas, or there is a power problem to the compressor (if you have a meter you can check this at the compressor terminals).
    To top up the gas and check for leaks, you need an authorised technician - sorry you are no longer permitted to carry out this procedure yourself. Call your local fridge guy.
    Hope this helps :)
Combustion switch error on windy days
check gas pressure and flame sensor
Jan 06, 2018 | Coleman Heating & Cooling
Where is the oil pressure sensor located on a 2014 Dodge Charger SE
Kelli, on 2.7 motor it is by oil filter above steering rack, in the eng. block, I think some may behind alternator and bracket also.
If these location do not seem to be right, do a online search with your info. and engine size.
Dodge Magnum oil pressure switch oil pressure light
Chrysler 300 2 7L oil pressure sensor location
Mar 20, 2016 | Dodge Cars & Trucks
Where is oil sending unit located?
You're vehicle has two sensors for the oil,an oil pressure sensor switch & oil pressure sensor.If oil pressure gets below 6psi,the oil pressure sensor switch will turn a dash light on to let you know the pressure is at a dangerously low amount.So if you've got a dash light on,the pressure sensor switch needs to be replaced.Its located to the right of the oil filter housing,on a 2.0 liter.Its located to the left of the oil filter housing,on the 3.0 liter.
If your oil pressure gauge is reading inaccurately,you need to replace the oil pressure sensor instead.Its located near the ac compressor.
Oct 15, 2015 | 2003 Ford Escape
Where is tire pressure module 05 toyota sequoia
Each tire has a module and the receiving unit in the car typically under the dash. To reset it:
1. Park the vehicle in a safe place and turn the ignition switch to the "LOCK" position.
2. Adjust the pressure of all installed tires to the specified cold tire inflation pressure level.
3. Turn the ignition key to the "ON" position.
4. Push and hold the tire pressure warning reset switch until the tire pressure warning light blinks slowly three times.
5. Leave the system with the ignition switch in "ON" position for a few minutes, and then turn the ignition key to the "LOCK" position.
May 25, 2014 | 2005 Toyota Sequoia
How to fix cold rest on HP lazerjet 5100
Cold reset CAUTION: A cold reset will reset the HP Jetdirectcard, even if removed. Print the Configuration page before performing a cold reset. The customer must have the ability to reconfigure the HP Jetdirect card and be willing to accept this responsibility.
  1. Turn printer off.
  2. Hold the ONLINE key down.
  3. Turn printer on.
  4. Continue to hold the GO key until the printer reads Cold Reset .
  5. Release ONLINE.
    • Initializing appears.
    • Then, Restoring Factory Settings.
    • Followed by Offline.
  6. Press the ONLINE key to put back online.
    hope it helps, if so do rate the solution
Nov 29, 2010 | HP LaserJet 5100 Printer
Bosch dishwasher Water pump not stopping
Hi.
You need to replace the pressure switch located near to the pump, in the drain assembly.
The main function of the pressure switch is to turn off pump when there is no more water.
The pressure switch can be tested reading ohms on switch contacts and jumping the switch. This must be done by a technician.
You can get parts and a quote on repair calling Bosch at the number listed on the manual.
Regards.
Nov 20, 2009 | Bosch Dishwashers
Changed right front tire now reads zero on dash light is on
Your tire pressure monitor needs to be reset whenever you change or rotate your tires...
1. check and make sure that your tires are inflated to the correct pressure
2. turn the ignition switch to the ON position. If the low tire pressure warning light comes on, push and hold the tire pressure warning reset switch (think the switch is in the glovebox, but not sure) until the warning light turns off and then release the switch.
3. now press and hold the tire pressure warning reset switch until the low tire pressure warning light blinks three times.
4. initialization is *not* completed until driving at the vehicle speed of 19 mph or over for more than one hour. the tire pressure monitoring starts when initialization is completed.
Aug 24, 2009 | 2008 Chevrolet Tahoe
Low tire pressure warning light stays on
I brought my RX350 to the dealer for this problem before. They told me to inflate my tires to 36psi for winter time although the recommended pressure is 30 psi
Dec 03, 2008 | 2008 Lexus Rx 350
Amana ACD2234HRS Side by Side Refrigerator Logo
191 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
