Have just installed new drum and there is a black spot that repeats itself on every copy made. Is this a problem with the drum's surface coating? Can I clean the drum?
The problem was indeed caused by a defect in the drum. The drum surface had a small spot where the coating was missing. The drum makes three revolutions during the copying of an 8 X 11 sheet and the defect is seen on the paper as three distinct black spots. The drum had been poorly packaged for shipment by the supplier. A piece of lightproof black plastic was wrapped around the drum to shield it from any light during transiting from the shipping box to the copier. This piece of black plastic was poorly positioned and wrinkled. Additionally, as received, the drum - sealed in a light-proof bag was jammed into the shipping box and I have no doubt that the defect in the drum surface was caused by this poorly packaged shipment. I reinstalled the old drum and hopefully I can finish the current job before the drum counter times-out and shuts down before I can obtain another new drum from that company.
kodak esp-3 printer - sucked up all the paper, got half way and quit. now the power won't come on,...
(More)
kodak esp-3 printer - sucked up all the paper, got half way and quit. now the power won't come on, and i can't get the paper out. help?
Hi Pritesh81, I saw your recent post regarding a Dell XPS 710. Can you help me diagnose mine? It...
(More)
Hi Pritesh81, I saw your recent post regarding a Dell XPS 710. Can you help me diagnose mine? It won't boot, I see the solid amber LED when plugged in but when I press the start button the power cuts after 1/4 second. I cannot locate the 4 LED indicators you mention within or outside the case.
Light up above the copy button blinks on and off and I can not copy, also when you lift the cover...
(More)
Light up above the copy button blinks on and off and I can not copy, also when you lift the cover you can see the copy bar move back and forth an inch or less.
