Question about RCA DRC8300N DVD Recorder/VCR
Dvd sound isn't working
When we turn on the DVD Player the sound doesn't work however it works fine for the TV and Cable
  • 5 more comments
  • Anonymous Nov 18, 2007
    I have my dvd player hooked up to my dish reciever. I have a picture but no sound the sound works when its on tv but I can't hear my dvd.I don't know if I have something hooked up wrong
  • PARKER1951 Nov 30, 2007
    WAS WORKING FINE FOR ABOUT 6 MONTHS AND THEN EVERY TIME I PUT IN A NEW DVD MOVIE THE PICTURE WAS BEAUTIFUL BUT ABOUT EVERY 3 MINITS OR SO THE VOLUME GOES OUT AND IN REAL QUICK ALL THE WAY THROUGH A MOVIE. ANY BODY HAVE AN IDEA. I TRIED DIFFERENT MOVIES TOO AND ITS HOOKED WITH AN HDMI CABLE
  • Misti96 Dec 06, 2007
    Trutech DVD Player (TT 320)....also no sound, but we do have a good picture. Volume is up on both the DVD Player and the TV. Several people have double checked that we have the cables in correctly...and still no sound! Can you help?
  • jreel Jan 09, 2008
    i have a sony slv-d350p dvd/vhs combo setup, and the sound stopped working on the dvd player. sound still works fine on the vhs, so i know the cables are setup fine, and ive tried multiple dvds so i know it's a problem with the dvd player and not the discs. the picture is still fine with dvds though, it's only the sound that isn't working.
  • jimchar2 Feb 06, 2008
    No sound!!!!!
  • Rudy Lopez
    Rudy Lopez Jun 07, 2008
    phillps dvp642/37 has no audio when playing dvd but got good picture
  • bobert343 Jan 01, 2009
    I have the same problem with the Sony SLV-D350P. Sound works when playing a VHS but not when playing a DVD. I tried almost every menu option and even opened up the unit to check for bad solder connections, etc.
    Sergeant:
  • 349 Answers
In addition to the suggestion which I fully concur with, there is one small thing I would add. Kari you may not be aware that there is often an "internal setting" in the dvd player for its output volume. Sometimes the setting is inadvertently changed to a permanently "muted" or silent mode so that no audio can be heard. This internal setting is usually accessed by pressing the "Setup" button on your remote control and browsing through the main menus to the "Audio" or "Sound Setting" submenu. Once there you will see if the settings are correct in order to HEAR AUDIO (sound that is). Be sure to turn the "MUTE" to "off" and set the output volume to about 3/4 high setting. Then get out of setup mode and play your dvd. My point is this...on some "kareoke" feature units I have found many people mistake the front manual volume control for a DVD audio output level control when playing dvd's. This is not the case..the output volume settings are "internal" and accessible through the remote control only. Hope this helps Kari !- hattonhall
Posted on Sep 08, 2007
I don't know if it will help or not, but I had the same problem. The VHS would have sound but DVDs wouldn't. I went through the different options on the DVD for sound(surround sound, ect) and changed it to a different one. After that, I had no problem with the sound. I did find there were a few DVDs I didn't have to do that to, but most of them I did. I don't know why it would make a difference though, but it's worth the inexpensive try:)
Posted on Sep 20, 2008
    Scholar:
  • 133 Answers
You may need to hook up the DVD player to your sound system (if you have one) or into the back of the TV properly (if you don't). Alternatively, turn the volume up on the DVD player itself, not just the TV, they usually have separate volume control.
2 Suggested Answers
SOURCE:
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
My Insignia Blu-ray DVD player and our Panasonic DVD player are playing only the sound with no picture. We put the correct imputs on the TV. They were playing fine a few days ago. We have Charter cable....
Sounds like the input board on the tv fried. (45-65$ fix if that's it)
Try the same two devices on different inputs , ie change from hdmi to component , or just use hdmi 2 instead of one, you get the idea.
Make sure the devices dont work on other inputs on the tv.
Then take a different device , like a 3rd dvd player and try it.
If nothing works in that input but works in other inputs the tv input board might (likely) need replacing.
If the third fresh device does work in that input , it is both dvd players or the cable you are using. (try to use a different cable in the tests than the one you have already used. )
Feb 13, 2018 | Zenith DVB312 DVD Player
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
My dvd player and tv blink on and off . When the dvd is unplugged the tv is ok? Whats the problem?
It sounds like your DVD player is the problem, not the TV. Check all the connections from the DVD to the TV and the power cord to the DVD and make sure they are all connected correctly and tightly. If that doesn't help try replacing the cables connecting the DVD to the TV. After that try using a different kind of connection (switch from S-Video to composite or component, or vice versa). If none of that works, the DVD player may be bad. Most of the time it isn't worth having it looked at for repair.
May 22, 2011 | Televison & Video
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Sep 14, 2009 | Televison & Video
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Jan 09, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
RCA DRC8300N DVD Recorder/VCR Logo
792 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
