Question about Nextel i860
Changing full house on i710
How can i get the bronze looking wire loose to change the housing on my flip part
    New Friend:
  • 133 Answers
Need more information
Posted on Dec 05, 2007
SOURCE:
How do I connect an old 3-way toggle switch to my new 3-way dimmer?
Cookrobert- you have to determine wich wire is the common wire in the box (house). Look in the box and see wich two wires ore in the same sleave. (These will be your travelers, (more than likely a black and a red) the wire that is in its own sleave (black)with a white tied to other whites is the common. Now the dimmer will tell you wich wire is commom. Tie the tow commons together. The green wire is ground if your house does not have ground , cap it and forget the green, if your house does have a ground (bare copper wire) then connect the green to the bare wires is the house box. Now your to travelers on the house side will tie to the two travelers on the dimmer side. Once you have found the traveller's on the house side and dimmer travelers they can be flip flopped. It dosnt matter. Just as long as they are the traveller's it will work. It sounds complicated but I'm sure you got this. I'm a 30 year electrician. (master).. I'll be looking for your update my friend. Good luck
Jan 21, 2015 | Electrical Supplies
How to change the housing on the blackberry 8220
search on you tube how to change housing.it will show you in detail how to do it. please rate my answer.
Jun 29, 2012 | RIM BlackBerry Pearl Flip 8220 Cellular...
How do I change the lightbulb on my lantern-style carriage house exterior fixture? It is wired flush to the wall and has a decorative filament on the top. Beneath that are two little knobs that appear to...
problem with most outside lights are, they tend to get hard to open because they are outside, without being there to look at it, i would say that you need to get a ladder and look at the light and see if you can see the threads on any of the knobs, then if you do gently use a pair of plyers to remove the knobs, hope this helps
Dec 03, 2011 | Home
How do we change the direction of the blades on the fan with the remote control (no pull chains)
hello lovesun... usually on the fans with out pull chains there is a switch on the top of the motor housing which you have to use to change the direction. Joe
Apr 29, 2011 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
My tail lights stay on, why
Try this, Loosen the two bolts that holds the front master cylinder onto the handlebars. Slide the master cylinder as close to the right handlebar switch housing as possible. If that doesn't extinguish the light, your front brake light switch is probably broken.
To change the switch, you'll have to open the right handlebar switch housing by removeing the two bolts that holds it together, take the throttle and idle cables loose and get the lower housing loose from the handlebar. The switch is held into the inner face of the housing by a single screw. Take the switch loose and desolder the two wires leading to it. Replace the old switch with a new one and solder the original wires to the new switch. Reassemble the throttle assembly and the switch housing. Check the throttle for proper operation. Make sure the throttle "snaps" shut when you release the throttle grip. Improper assembly or adjustment of the throttle cables can cause the loss of control of the motorcycle resulting in serious injury or death.
Good Luck
Steve
Oct 01, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. [email protected]
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
How do i change the frequency on the fan unit?
You should have a full function remote control that does this for you. It probably wasn't programmed into your unit. I'd check your manual for the information. I'm not sure if this is what you're looking for, but feel free to ask me further question's if need be. Sometimes you can set these units manually above the light (in between the blades on the housing), but I'm not sure about this particular unit. But I do know it's a 3 - speed fan unit, and is normally ran from the remote control unit. Good Luck to you, and feel free to ask any further questions that you may have. - Jim
Apr 06, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
How to change full cover on nokia E71? step by step guide
Nokia E71 Housing Fascia Replacement Faceplate Cover, Restore your ... or alternatively use the corresponding tools to change it by yourself.) Package include: Full Housing Replacement Cover for Nokia E71
Full Housing Replacement Cover for Nokia E71 (Grey) * 1
Front Cover
Back Cover
Middle Cover
Keypads
Accessories as the picture shows
Keypad *1
T6 Screwdriver and an opening tool
Aug 12, 2009 | Nokia 6085 Cellular Phone
Check engine light after an oil change?
call corporate and make jiffy lube pay to repair.... the blue wire is original equip or alarm or ?...code check the vehicle to find what it says it is... free at local aout parts houses.... get underneath adn check for areas they disturbed for failed loose connection.. check battery grounds and even fuel cap for anything loose... too many possibilities yes..advise
Jan 14, 2009 | 2002 Chevrolet S-10
Bottom screen
a wire has disconnected, you have to take ds apart again (not fully) just so you have access to motherboard with black and white wires showing. look to where the black wire is fixed on and below that to the edge of the board you will see a tiny piece of see-through plastic with black lines through it, (mine had come loose and i had fastened ds up whilst it was curved underneath board). you should also see there a slot approx 2mm at most with 3 / 4 bronze/gold prongs ( very much like smaller version of the large wide wires and slots they fasten into) you dont have to flip anything up to get this wire in or out, just slot in carefully (i used tweezers) as far as will go, making sure you dont disturb placement of any other wires. now put shell back on and before you put screws in just switch ds on to see if problem is solved. hopefully ! mine worked fine after this.
Jan 07, 2009 | Nintendo DS Lite - Onyx
Cell Phones Logo
Top Nextel Cell Phones Experts
Ekse
SANDIP MISTRY
SANDIP MISTRY
William Norris
William Norris
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
