Question about INOi MP18020 GB MP3 Player
Inoi partition error
My inoi says partition error when i turn it on and when i put the usb and it together it shows nowhere in my computer
  • Anonymous Apr 23, 2008
    my INOi says partition error when i turn it on and try to get to the music, the battery is fully charged and it was working just a few days ago.... please help
  • Anonymous May 21, 2009
    me 2
My INOI also has the same problem. It says "PARTITION ERROR" when I turn on (using the USB drive plugged into the computer). Upon reading and researching on the Internet, I feel that the battery inside may be weak for startup. Looks like installing a new battery would help ??
Posted on Feb 12, 2009
I have what I think is an Inoi Sata multimedia hDD ( Square aluiminum case) .I have connected it to a Windows 7 computer and has failed to be recocognised. Where do I find suitable drivers thanks
you should not need drivers for that all, windows should be able to recognize it.
These things usually need an external power supply, first check if it is connected.
Try it with a different computer. If it works then I suggest a system restore on the other comp.
If it doesn't work (which is likely) then you should take apart the metal case, remove the HDD (which is a totally standard desktop HDD) and plug it inside the comp with the SATA port. Windows then will correct the disk errr upon turning on. If it doesn't work this way either then it's dead. If it works flawlessly, but when put back into the case it doesn't wok again then the housing is faulty.
Aug 11, 2011 | INOi HD370 300 GB USB 2.0 Hard Drive
My inoi 500gb hard drive wont work: on the pc its recognising the usb but not showing up. on the tv its saying no disc. i know its a hard disc fault but is there anything i can do since the...
I am a little puzzled (from Manchester). I think you are saying that this drive is an external drive powered by usb connection to your pc. If this is so, have you tried it on another pc? I assume you are getting the "USB Device not recognised" message when plugged in. Try plugging it into the usb ports on the backplate (if it is a tower pc that is). If all else fails then try and download a linux (ubunto) distro and burn to dvd. Boot your pc from the cd and linux will appear as your desktop. now plug in your drive and if it opens ok then copy the contents to your original drive in the pc. If all goes well you can then delete the partition on the usb drive and when back into windows you can format the drive and if lucky you can copy back the pics back onto it. If this does not work then the drive is shafted. The only way to get the data from it is to give it to a data recovery company who will charge the earth but at least you will have the pics.
Good luck
Jun 20, 2011 | INOi Computers & Internet
This is caused by a defective hard drive. Possible reason is dropping the player. You need to change the hard drive to make it work again. You need a 1.5" (20GB) hard drive.
Mar 13, 2010 | INOi MP18020 GB MP3 Player
Inoi mh386 wont play on tv anymore- bad sectors?
Sounds like a Bit recognition failure. Is there a way to establish the firmware or software on the harddrive you may need to http://inoi.com/English/DriverDownloads.asp
This may resolve the issue and May you enjoy
Giligan Island LOL jk
Oct 18, 2009 | INOi HD370 300 GB USB 2.0 Hard Drive
Remote won't connect with the 320gb Inoi media player
Can you please tell me, whether the drive responds when you press the “STANDBY” button on the remote?
If the drive responds then the remote is working fine and the actual unit is faulty. If the drive does not respond then the remote is faulty. You need to buy or get a replacement from the seller.
All the best!
Apr 05, 2009 | INOi 320GB INOI HIGH DEFINITION 7200 RPM...
CAN I PUT A DVD ONTO A INOi mh386 EXTURNAL HARD DRIVE.
scan your xternal HD... it will help you....
from device properties > tools>check now
tick both option and wait for the job finished
Jun 12, 2008 | Computers & Internet
Inoi MP3
I have the same problem, sometimes, if I plug it up to the computer, with usb port and press the computer option, keep pluging and unpluging over and over it will reset and starts working again. But it still fails, It may have something to do with the internal battery being weak. Even thought it shows charged, may not be able to supply the current required to start the hard drive.
Jun 11, 2008 | INOi MP18020 GB MP3 Player
Manage partitions
go to device manager and uninstall the usb root hub and restart the computer if the usb still does not respond then call hp total care for the replacement of the motherboard as the usb drives has gone bad ..it will be replaced for free if u r in warrenty..or u will have to pay ..
May 05, 2008 | HP Pavillion ZV6000 Notebook
212 people viewed this question
Top INOi Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an INOi Audio Player and Recorder Expert? Answer questions, earn points and help others
