Question about GPX PDL805 Portable DVD Player
DVD player reads open and the when I push the play button it reads invalid key
How do I fix his problem? When I put the DVD disc in th player, it continues to read open. Then when I push the play button it rads invalid button. What is the solution? I don't have the manual anymore.
  • bnicole19951 Jul 01, 2008
    My screen won't come on and my disk won't spin. The battery is fully charged and the green light comes on the front showing me it is on. What can I do. My mother purchased 3 of these for us for Christmas and not one of them works anymore. One won't charge at all and the other one is extremely difficult to charge. You have to sit and hold the charger cord in place forever.
  • xoxb5xox Jul 25, 2008
    dvd say open also when i pree play it san invalid key
I am having the same issue with Toshiba SD-P1850
Posted on Dec 26, 2007
  • 790 Answers
Check the laser lens and or the ribbon wire.
Posted on Sep 08, 2007
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
DVD won't work when I play it in the DVD player
Read the owner's manual for your DVD player. Some brands (cheaper ones) are particular on the type of DVD to use (i.e. + or - DVD..). Most will NOT play a rewriteable (DVD-RW) disc.
I had a COLBY (WalMart) and it would only read DVD+R discs...
Dec 08, 2009 | Pinnacle Dazzle DVD Recorder
Dvd player says loading and won't play dvd
Disconnect the power,push the eject button and connect the power while pushing the eject button.
Dec 01, 2009 | Televison & Video
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
DVD gives an invalid Disc Error
This is quite easily, cause by ONE reason. The thing is, the lens is very very dirty, or had broken, try to replaec it if u can, or try cleaning it with cotton.
Mar 30, 2009 | Lite On LVC9006 DVD Player/VCR
Wharfedale DVD- 265 saying invalid disc
Check and see if there is dust or dirt or something on the lens. Dirt, grease and fingerprints will cause a DVD player to have read errors.
If it a new player, or under warranty, get it replaced. It sounds like it is failing.
Hope that helped.
Jan 01, 2009 | Wharfedale Televison & Video
How to play music cd's
Stop video playback first, then press CD MODE then press PLAY.
Dec 16, 2007 | Pioneer DV-C36 DVD Player
"invalid key" error
your set needs a tech take it to be repair you cannot do it yourself if you do not have a knowledge of electronics repair.good luck
Mar 17, 2007 | Cyberhome CH-LDV1010A Portable DVD Player
GPX PDL805 Portable DVD Player Logo
681 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
