Transmission & Drivetrain for Jaguar S-Type Logo
Anonymous Posted on Aug 23, 2013
1998 jaguar jx8 isn't going into first gear easily...have to rev it to go in, I have been using gears the original owner didn't...mountain driving and all. HELP
Denis Houle
Level 3:
  • Jaguar Master 1,414 Answers
  • Posted on Aug 23, 2013
Denis Houle
Jaguar Master
Level 3:
Answers
1414
Questions
0
Helped
498561
Points
4096
It look like the transmission input shaft still turning while clutch pedal is press. the clutch does not disengage enough. now engine off try to put in first gear then press clutch pedal start engine
1998 Jaguar Vanden Plas. When I put into drive will not go into gear unless I give it a little gas then jerks into gear. Then I have no power but hits all gears.
Question edited for clarity.
Question moved to model category.
One a manual shift, not enough clutch clearance or a worn clutch plate. On an automatic, you need to look at fluid levels.
2002 jaguar xj8 when I drive it won't go over 3000rpm
Jaguar wont rev 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > wont rev 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... Wont go beyong 3000 Revs s type 2001, wont go beyond 3000 Revs and it' in limp ... Question about 2002 X-Type ... My jaguar xjr8 year 2000 battery went dead started car went for short drive back ...
Jaguar engine cuts 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > engine cuts 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... engine cuts out and shudders at 3000 rpm won't accelerateobd code p0332 2002 jaguar x type 3.0 l P0332 - Knock ... Car is boging out in park and will not go over ... driving, don't worry about it.
Rev Won't go up
www.jaguarforum.com/showthread.php?t=14662
1998 Toyota Landcruiser Prado drive issue
If the car heats up trying to generate revs , then it Seems like the clutch plate is slipped.
1helpful
I have a grinding sound in the front of my 1998 mountaineer, also i have my abs light on, and was told i have a bad hub and a bad differential
checking gear oil is not checking for a bad gear or bearing with the hub that will also pop the abs change the hub because if grinding is indeed the hub not long from total failure which can cause accident as well as serious injuries
1helpful
Hi I'm an owner of a 1998 Honda Oddysey. I would like know the mechanics of using its automatic gear transmissions and specific function. For example when do I use D3 or D2 etc... And how do I shift...
Gear usage.
The Drive is for normal driving.
D2 is for hill/steep climbing drive.
D3 is for hill/steep going down drive.
If you have overdrive button, use it when you exceed 60mph.
That's all you have to do when you see roads that is going up nor down.
Thaks for asking FixYa!
Unable to get gears - car just revs in drive.
Standard or Automatic ???
Standard: the clutch is slipping, Automatic: the clutches internal are slipping, did you bother to check the transmission fluid level first ?????
1998 Mercury Mountaineer Transmission issues..
sounds like servo/solenoid problems for those gears run the fault codes or have it inspected and properly diagnosed by an accredited transmission specialist shop
it is running with no reported noises or other problems so at this point it will not need a new transmission
Top Jaguar Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Denis Houle
Are you a Jaguar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
