Question about Nintendo Wii Console
Remote lights won't stop blinking!
Right after playing a game, both of the wiimotes stopped working. No cursor on the screen. They won't power on. All four lights on the bottom just blink for a min or so when you try to turn the system on. Tried replacing batteries and turing system on and off by hand but still can't get wiimotes to work.
  • Anonymous May 25, 2009
    What I did was Turn my Wii off like Unpluged it for 2 min. pluged it back i and the remotes both went back to normal. yay!!!
    Problem Solver:
  • 13 Answers
Could have come out of sync you could try putting them in sync again or there could possible be something conflicting them.
Posted on Sep 08, 2007
    Problem Solver:
  • 13 Answers
Change the batteries
Posted on Sep 15, 2007
How do I fix my Wii remote?
Controller is probably broken -- Use a different controller.
Jan 14, 2013 | Nintendo Wii Remote Controller
I cannot get my Wii remote to move the cursor so I can click on to the net flix channel. What button do I push?
The WiiMote cursor is moved by you pointing the WiiMote at the screen. The cursor will move based on the signals it receives from the sensor bar, which shoudl be placed at the top or bottom of your TV.
May 15, 2011 | Nintendo Wii Sports for Nintendo Wii
We tried to reset the sync buttons and the blue lights on the remote blink repeatedly but it still does not communicate with the game
Try removing and reinstalling the batteries from the wiimote and the unplug the wii power cord at the outlet end for a couple minutes. I had that problem once and this seemed to fix it.
Mar 07, 2011 | Nintendo Wii Console
Just added a new wii controller now I have 2. I activated but when I try to use it to play tennis against my husband only his remote works mine wont swing. The cursor is on the second one is red and lloks...
When you are on the screen where you select number of games, use the second WiiMote to click on the two characters on one of the sides of the screen. that will assign them to the player 2 controller. Hope this helps =)
Mar 25, 2010 | Nintendo Wii Console
Wiimotes stopped working right
How are they not working right? If it is that they go all over the screen, the receptor may not be positioned right or you may not be. If it just doesnt work at all, I guess you would have to buy new ones.
Jan 12, 2010 | Video Game Consoles & Games
Wii Remote A/ B problem
I know this sounds silly, but be sure that you have fresh batteries in each Wiimote and that you have them in the right way.
Whenever you start up your Wii, the first Wiimote that you press a button on becomes controller number 1 and then subsequent Wiimotes are added in the order a button is pushed on them. SO, if you are thinking that you have remote 1 because that was the one that was remote 1 last night, it doesn't necessarily mean that it is so. Be sure that whenever you activate a Wiimote, the lights flash - 4 lights flashing mean strong battery, 1 light flashing means replace; when flashing stops, the number LED that is lit from the left denotes which remote you have. Make sure that is the same Wiimote that you select a game with, and make sure that is the one you press A&B together with to start the game.
If it doesn't work, shut everything down and start up using the other Wiimote. If that DOES work, then it could mean that your other Wiimote is not syncronized with the console. See the directions in your Wii manual on syncronizing additional Wiimotes (they're called Wii Remote by Nintendo) to your console.
Good luck. If all the above fails, you may want to go to www.nintendo.com and request customer service.
Mar 25, 2009 | Nintendo Wii Remote Controller
Wii remotes have stpped sending signals.
When you first press a button on the Wiimote, how many lights blink? If the answer is 1, then your batteries may be too low. 4 blinking lights mean that you have fully charged batteries.
Other than that, you may want to consult the user manual with regards to re-syncronizing your Wiimote to the console. If you don't have the manual any more, and you have at least two blinky lights, then press the red syncronizing button on the console first, then the corresponding button inside the battery cover on your Wiimote. Reboot the Wii and see if it works.
Mar 22, 2009 | Nintendo Wii Remote Controller
Nunchuck wii problem
Most likely not a fault with either. Try not touching the nunchuk while the game is powering up, as moving the joystick while the game is powering up can cause these issues. If the problem is still happening, click the Wii Home button and open the Wii Remote Settings at the bottom of the screen. Choose the option to reconnect the remote, and then try again. If this doesn't work, ai am not really sure what is the issue. You may need to send to NOA for a checkup.
Mar 13, 2009 | Nintendo Controller add-on Nunchuck for...
Cannot get the gun sights to move in wii play
Ensure that your not too close and not too far from your TV, and make sure that your sensor bar is properly set atop (or below) the screen.
Aiming takes a minimal amount of movement once you get your cursor on the screen. Big motions are not necessary to move your sights around the screen - just little movements with the wrist. Once you find that sweet spot, you should get good experience with the Wiimote.
Finally, make sure the batteries in your sensor bar (if you are NOT using the one that came with your Wii) and the batteries in your remote are fully charged. To know if the batteries in your Wiimote are charged, the first time you press a button on the Wiimote after turning on your Wii, you'll notice that 1 to 4 of the blue LEDs will be blinking. If all four are blinking, the batteries are good. If only one blinks, time to replace them.
**NOTE: If you don't like my advise, that's fine. But please don't rate me a '1' just because my answer doesn't help. That's what 2 diamonds are for. Thanks!
Feb 04, 2009 | Nintendo Wii Play for Wii
Wii remote won't work. Just lights up
pair the wiimote with the wii. open the slot where the sd card goes press the red button then open the wiimote and press the red button right after
Feb 25, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
1,155 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
