Question about Bosch WFVC5440UC Washer
Bosch vision error code E01 on washer - Bosch WFVC5440UC Washer
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • Bosch Expert
  • 86 Answers
Error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Posted on Dec 11, 2015
3 Suggested Answers
SOURCE:
Macmarkus
  • 2605 Answers
SOURCE: I have a Bosch Vision 500 with a few error codes.
Hello, welcome to FixYa.
Based on your post I understand you have a Bosch WFVC5400 "Vision" series washer. Hopefully the info below will supply you with the assistance you require.
I will start by letting you know though the E27 & E95 error codes are not common nor are they listed in the service manuals, they are known to be associated with door lock and communication errors. These can be due to the door lock mechanism failing and/or is overheating. It is recommended that you unplug the appliance for 30 minutes and try again.
The E01 error indicates a door lock error directly. Though again this can manifest from an improper draining and not necessarily a lock problem.(drain time exceeded).
If the unplugging the uit fails to rectify the errors, you will need to first check the pump/drain lines and if all else fails replace the lock assembly unfortunately....but that's getting ahead of ourselves.
Try this first...
The next step is as follows,
Following this ( or in reverse order it's your call if you think there may be substantial water still present ) I'd do this step first...checking the pump filter. It may be a good plan to have towels close by, or a wet-dry shop vacuum.
It's as follows...
Then the filter removal...
That should resolve the problem, As I also alluded to before, there is a possibility the lock itself is faulty, but not likely.
Thanks for choosing FixYa and good luck. Let me know if you need further assistance or if any of this is unclear.
**NOTE:too much "He" detergent or the use of non-He detergent can also cause too many suds which are opposition to proper operation of these machines and can and DO cause all kinds of error codes**
Once the issue is resolved I recommend running the unit through the hottest temperature possible on the longest cycle possible and add some product called "washer fresh" or "Affresh".
Both are designed to remove residule soap buildup inside the tub assembly and prevent errors associated with soap suds, which usually manifest in errors with the pump and lock.
Regards,
Macmarkus :)
Posted on Aug 28, 2011
  • 88 Answers
SOURCE: front load washer Bosch Vision 300/500/DLX will not drain getting a code of E27 can you help. Can't find the code # in the booklet that came with it.
A code E27 means a problem with the door lock. Try unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right corner you will see a white plastic pull cord. Pull the cord and pull open the door. If that doesn't reset the door lock you will need to replace the lock.
Posted on Nov 22, 2012
How to start a diagnosis test on Bosch dishwasher model SHE3ARF6UC/21 will not start because of E01 code
Error code E01 means that your Bosch dishwasher is experiencing trouble with the motor.
Feb 19, 2018 | Bosch Washing Machines
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Started with E01 and E25
The E01 fault code means that the dishwasher has suffered a power module failure.
The programming of replacement power modules E01 up until E05 has been locked down by Bosch so in the event of an error code of this type it's recommended that you contact a Bosch approved dishwasher engineer.
Apr 12, 2015 | Bosch Dishwashers
How do I find the codes on my washer bosch 500
On http://www.onlineonderdelenshop.nl/blog/storingcode-fout-code-bosch-siemens-wasautomaten-wasmachine/ you can find some Bosch codes in Dutch with some explanations.
Oct 19, 2014 | Bosch WFVC540SUC Vision 500 Washer in...
E01 error
The control board is seeing the door as open even though it may be closed. Here is how to repair:
http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-code-er%3a01/1
Jul 24, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Error code E12 Bosch washing machine front loader
I have the Bosch Vision 500 Series with the E:12 error. My issue was the water inlet valve. When the washer was filling up very little water could be seen coming into the washer and if you just hit the button eventual you would get enough water usually three times during entire wash cycle. Replaced the water inlet valve myself in about 5 minutes very easy. YouTube videos show exactly how to do it. Now the water comes in almost covering half of the front window. Just finished first wash without and problems.
Apr 10, 2012 | Bosch Washing Machines
Error code E:01
Hi and welcome to Fixya, The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary. I'll watch for you to respond with the result's. Good luck. Macmarkus :)
Jun 07, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch WFVC5440UC Washer Logo
2,705 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
