Question about Lexmark P4350 All-In-One InkJet Printer
Scanning It will scan just fine but it will not send it to my com. to post on a page.
  • 62 Answers
Try starting the scan from the PC. You can use either the Lexmark All-In-One Center application, (Look under Lexmark 4300 Series in your Start Menu). This will give you a little better control of where the scanned image is being stored on your computer.
Posted on Sep 24, 2007
SOURCE:
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
Nov 15, 2013 | Konica Minolta Bizhub C284 Color Copier /...
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
The manual that comes with my brother MFC-7840W covers all functions ACCEPT scanning! How do I scan multiple pages into ONE file so I can send a single file to someone. Thank you, Jeff Vanskike
Information on the scanning function can be found here:
http://welcome.solutions.brother.com/bsc/public/as/au/en/faq/faq_list.html?reg=as&c=au&lang=en&prod=mfc7840w_all&Cat=107
In order to scan a multi-page document into a single file, you must configure the scan to use a file type that supports multi-page documents. For illustrated instructions of how to scan multiple pages into one file instead of each scan being saved as a separate file go to here:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002500/000078/faq002578_001.html?reg=as&c=au&lang=en&prod=mfc7840w_all&Cat=107
Feb 10, 2011 | Brother MFC 7840W Printer
Symbol LS2208 I need to scan in a barcode then add a tab then input 1
From the LS2208 Product Reference Guide you should print and scan the following barcodes:
Begin New Rule Adobe page 232 of 342
Send all data that remains Adobe page 246 of 342
Send tab key Adobe page 286 of 342
Send 1 Adobe page 270 of 342
Save Rule Adobe page 232 of 342
That should do it. If you find the scanner sends the 1 too quickly after the tab key you may want to scan Send Pause in between the Send tab key and Send 1 statements.
Mar 09, 2010 | Symbol LS2208 Handheld
HP Laserjet M1522nf Multi page scanning problem
Check this thread in HP forums:
Second Page Scan is Garbled on HP1522nf
Download the file attached to LARS post halfway down the page and follow his instructions on how to unzip and install it.
Hope this helps.
Sep 11, 2009 | Office Equipment & Supplies
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
Dell 1815 dn all in one
When scanning a document it is common for the scanner to use a high resolution and color mode both of which increase the size of each scan. There is a limit on the size of an attachment which varies with your e-mail and or Internet provider. It is best to keep attachments as small as possible. You can change this in the settings menu going to black and white and setting the DPI (dots per inch) down from 300-600 to 150 or even 75 and the scan will be fine but a smaller file size. If you are sending color pictures you can make them smaller but the quality will suffer some and you will still need more then one e-mail but with adjustment of the settings you can reduce it to a minimum. I hope this is useful to you. Good Luck
Jul 21, 2009 | Dell 1815dn All-In-One Laser Printer
I want to Scan and send by email in PDF format all pages !!
Looking at my manual , it tells me you have a software user guide on the cd-rom ....this is where you will find the answer.
Jun 02, 2009 | Brother MFC 7840W Printer
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
http://www.devicemanuals.com/guide/All-in-One%20Products/HP/HP-PSC-950-All-in-One-Owners-Manual-==TVRFME56VTI=.html
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=34579
May 27, 2009 | HP PSC 950 All-In-One InkJet Printer
How do you scan and save to computer
If you go to this link by clicking here you will be able to access, on page 40 a complete set of instructions for scanning images and saving them to your computer. You might want to create a folder in your My Documents that you call my scans or someplace to keep your scanned images so you'll be able to send them to the same place each time you scan and know where to find them...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 21, 2009 | Lexmark X2600 InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
105 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
