Question about ViewSonic VA1703wb Monitor
Screen display the screen has moved to the rightside of the monitor and there is a black line on the left. I cannot move the mouse pass the edge and into the black space. There doesn't seem to be any screen adjustment buttons. Please help
    Problem Solver:
  • 13 Answers
You should be able to adjust these settings in the display settings which should be in the controll panal some where depending on which operating system you are using and what graphix card.
Posted on Sep 08, 2007
SOURCE:
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
How do i manually switch my screen back to laptop after switching to another monitor ?
If your using a windows computer like Windows Vista, 7, or 8. Right click on your desktop and click screen resolution. It'll bring up monitor properties, you can click the other monitor plugged into your computer and set it as the default. If your graphics card supports it you could even click to extend displays and use both at same time, moving your mouse past edge of one of sides of your screen to move to other display.
Aug 15, 2014 | Sony VAIO Computers & Internet
Mouse cursor disappear on hp w2371d
See this... http://h30434.www3.hp.com/t5/Desktop-Lockups-Freezes-Hangs/Disappearing-mouse-pointer/td-p/1568463
If it only disappears when you move it left or right off the edge of the screen, your video software may think you have a second monitor. Tell it different.
Aug 04, 2014 | HP W2371D 23 Full LED Monitor 16:9 5ms...
Google page not centered on monitor
You don't specify if you're PC or Mac User.
If PC user then it should be easy to fix. Top right corner of your web browser program should have three symbols: a minus sign, a box and an X.
Try clicking with your mouse on the box. It should make the program viewed slightly smaller. When it does you can move your mouse to the top of the window (usually a blue bar) and while clicking the left mouse button you can move it wherever you like (centre it).
It's more of a temporary solution and if the window is too big to fit the screen you can move the mouse to the left, right, bottom and when you move over the edge it will turn into a line with arrows at both ends.
When it does that you can click the left mouse button and drag the edge of the window to make the window smaller. Adjust each side as needed.
To fix things permanently you may have to adjust your monitor's settings using the buttons on the monitor itself. For that you're on your own as I don't know how to adjust every monitor's settings.
Jan 11, 2014 | Computers & Internet
My laptop screen resolution is already set to 1200 *600 and windows 8 does not support in that screen resolution they want to 1200 *768 what can i do
  1. Open Screen Resolution by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering Display in the search box, tapping or clicking Settings, and then tapping or clicking Display.
  2. Tap or click Adjust resolution.
  3. Tap or click the Resolution list and find the resolution marked (Recommended). This is your monitor's native resolution-usually the highest resolution your monitor can support.
Screen Resolution in Control Panel shows the recommended resolution for your monitor.
Monitors can support resolutions that are lower than their native resolutions, but text won't look as sharp and the display might be small, centered on the screen, edged with black, or stretched.
Oct 12, 2013 | Samsung N150 (36725723009) Netbook
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
My monitor screen is to far to left side i can't
Try to change the manual display settings in your monitor.You can see those to the side or below the monitor screen depending on your monitor make
Mar 04, 2010 | Gateway GT5220 PC Desktop
When I move the mouse off the side of the screen
Try changing the screen resolution of your screen
Aug 19, 2009 | Apple Computers & Internet
Cursor and pages opening up off the right side of my desktop
This is a monitor setting. use the menu button on your monitor to shrink the screen size from side to side. The menu button usually toggles you through the settings and the + or - buttons adjust the settings.
This happens a lot if your on a small desk and bump your keyboard against a low sitting monitor.
Regards
Mar 24, 2009 | Computers & Internet
Black dotted line on monitor
Hi , Do not panic ,It is to do with the display driver which you need to reinstall.
Jan 11, 2009 | Dell Inspiron E1505 Notebook
ViewSonic VA1703wb Monitor Logo
61 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
