SOURCE: video freezes up to vertical lines or blue or white screen
Clean the CPU cooler and everithing else from the dust!
Turn off,open the case, use air spray to clean.
(I use vacom cleaner and a small brush, but you risk your component if you do the same! I'm professional.)
SOURCE: Computer Freeze
I would suggest maybe backing up your data and reformatting it. Often that's the best solutiong
SOURCE: I am using DELL Inspiron
attach an external monitor to be certain the video card is ok,
next
Re-seat the video card cable to the lcd screen,
dell site explains how to remove top and keyboard.
your real issue may be the cable itself or the lcd screen.
SOURCE: Turned computer on one day
Try another monitor, then change the graphics settings to lowest possible, then reboot the PC, and see if your screen works again, if it does, check the documentation for your monitor and make sure you do NOT exceed the maximum color depth / resolution for your monitor, also, make sure not to exceed the refresh rate.
if this does not fix your monitor issue, check the cables for missing pins, freyed wireing / broken insulation.
Again, if this doesn't fix your problem, try the monitor on another PC, and if still a no-go, you may have a damaged inverter board in your monitor, or other componant / wire based issue.
If another monitor doesn't work on your computer, try swapping the graphics card out, it could very well be a dieing graphics card.
SOURCE: screen has a blue tint - no red
sounds to me either your video card is bad if your computer came with one or if your video card is integrated into the computer then the motherboard is bad.
Basically if you have a video card, it will plug into either a PCI or AGP slot and alot of times they overheat or the fans fail on them. If thats the case you would replace the video card. If you have integrated video on your motheroard meaning you don't have a card and you plug the monitor into the motherboard video connector then the motherboard is bad and would need to be replaced.
