Question about Sony PlayStation 2 (PS2) Console
Help!! Whenever I put in disk and press reset, ps2 doesn't read the games. Instead it goes to memory card editing thing. When I open the disk holder, the cd is not spinning. I don't know why and never encountered this kind of problem before. Plz help me.
  • hightrike Sep 08, 2007
    ps2 still reads disks
  • Anonymous Nov 06, 2007
    what the hell fuck my fucken playstation is being a bitch all my games wont load
The problem is the laser lense is dusty it 's tricky with a modchip or the new version
Posted on Nov 06, 2007
    i think you should go to gamescrew.com to learn the temporary fix if you don't have a warranty. Go to sony i would go here also WITH a warranty.that is the best thing if the temporary fix dosen't work.,.
  • 709 Answers
Hello , hightrike, You are experiencing what I believe is the dreaded Disc Read Error. This can be solved by opening the unit and thoroughly cleaning the inside from hair, Dust, lent. Clean the laser with a q-tip lightly soaked with Rubbing alcohol. Cloe it up and try it. Chance are you fixed it. if your problem is more severe, please check out www.playstationclinic.com Regard and best wishes, Greg at the Playstation Clinic
Posted on Sep 12, 2007
Hey man... I hd d same prob wen i bought d ps2 but it was at an earleir stage...wen i went to repair it, it was found dat der is an internal problem wid d wire of the cd player inside d ps2...actually smtmes it does happen dat but it can b easily fixd in a couple of min,.,.....U bettr go to d sony stores as ur console wil hv to b opened up to fix d prob....
Posted on Sep 11, 2007
Your lens are dirty you have to clean it with cotton budds with oil
Posted on Sep 10, 2007
SOURCE:
I do not know how to get my system configuration
PS2 drives are picky, Make sure your disk is clean and free of flaws. Also see if it is one of those blue shiney disks, they are the worst as far as readability goes.
If none of that helps then your drive probably needs adjusting. Link to instructions here:http://www.exploitstation.com/index.php?page=ps2repair
Good luck.
Mar 30, 2010 | Sony PlayStation 2 (PS2) Console
When we turn on the ps2 it does not go to the game it goes to this browser thing
WhEn u turn on your ps2 u can press the open button until it goes to the browser and click on the 1 that shows up too see your memory or click on the disk that shows up if it doen show up then eather your eye is dirty or game is dirty or 2 scrached or just put game in and it should go rght to the game hve fun :D
Oct 07, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 No longer reads my memory card!
that happenes to me all the time, wat i usually do is pull the card out, blow into the ports, then put the card in. wen the card is in, wiggle it from side 2 side and your ps2 should pick it up
Aug 15, 2009 | Sony PlayStation 2 (PS2) Console
PS2 won't read Original/Backup CD/DVD
The Purpose behind the guide to you is emulate your exploit disk, instead of using the disk you use, you're storing the exploit files themselves to your memory card ie. you're ps2 menu and HDloader and any other .elf file. Then you're using the PS1 (retail) game to cause a buffer overflow exploit to load the elf files stored on your memory card, once this is done you get that modified PS2 menu. As I said in the first clairication request the swapping stuff doesn't pertain to you becuase you have a mod chip installed. The main purpose for you to use what i posted eariler was to give you your modified .elf PS2 menu back (cuz all of your tools were stored before on your exploit CD wich is a non retail burned copy) this gives you a way to boot up with things that are native to the PS2 (memory card and retail PS1 game) from the .elf PS2 menu you should be able to see better what is going on becuase you can access each disk type contents from that menu and should be able to launch the game (if your laser lense is functioning enough to read retail PS1 games) from the menu itself. Or if you've been using HDloader plop that .elf onto the memory card (explained on my site) and just navigate to that via the .elf PS2 menu and you'll at least be able to load games stored on your hard drive. This is just something you can use till you get your new PS2 chipped out.
Of coarse this is all speculation. If your PS2 can't even read retail PS1 games none of this will even work.
Sry I don't know anyone that does the chipped stations nemore. I'm sure someone on this site still does though.
Dec 15, 2008 | Sony PlayStation 2 (PS2) Console
PS2 8MB memory card not detected at all!
try put in another slot or blow or make shore all that silver stuff is on it
Nov 22, 2008 | Sony PlayStation 2 (PS2) Console
A heavy object fell on my ps2 slim line and now it can't read games but reads dvd movies
sounds like it bumped the laser alignment out of wack do a google search for ps2 slim laser alignment howto and it should bring up the steps you need
thats the ps2 fat video below but will tell you the steps required
Oct 03, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 problem
i have had the same problem and i just kept using my disc cleaner and polisher and after a few times it work. if that didn't work get a laser disc cleaner for your ps2
Feb 05, 2008 | Video Game Consoles & Games
Ps2 memory card
Hi Lofatman,
If this problem happens with the memory card when its in either slot 1 or slot 2
I suggest you clean the contacts of the memory card.
If it just happens when you have in Slot 1 or Slot 2 only,
 Go to Radio Shack and get a Can of contact cleaner that has a Brush built into the Spray nozzle.
  1. Turn off the PS2 and disconnect the power cord.
  2. Use a small screwdriver to press open the memory card slot. Do not use too much force, its delicate.
  3. Push the Brush sprayer up into the memorycard slot and spray a little and brush away at the memory slot contacts.
if you do not have success with that, you must open the PS2 case, and Remove the Controler ports and clean up the whole controller port assembly.
If that doesn't work, and your frustrated and not Electronically skilled enough to do this.  I can get the PS2 in tip top shape, for $32 and that includes return shipping.  I run the website www.playstationclinic.com
This should put you in business.
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
