Question about Yamaha RX-495 2 Channels Receiver
How should I read these commands?
I received this Yamaha Receiver from my mother's estate; which did not carry instructions. Could you please help? Case-in-Point: I always "light up" first the AUX on the Yamaha screen(that connects to the DVR)but nothing comes from the speakers. Am I not pushing Tape 1 or something? If you could e-mail what the main commands are and their adjacent buttons for other/different commands, I will appreciate you. Thank you for your time, Lisa S Kelly
SOURCE:
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
  • 4 Answers
SOURCE: no zone 2 sound coming from yamaha amp rx-v861
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Posted on Aug 04, 2008
Ajkill
  • 2035 Answers
SOURCE: yamaha rx-v2500 receiver how to hook up speakers
You can hook the speaker like this one center speaker , two front right and left speaker,and then rear right and left speaker and one sub speaker in the unit ...
Good luck...
Posted on Oct 06, 2008
  • 6 Answers
SOURCE: can't get audio from HD TV to run through Yamaha receiver speaker
be more specific!...how is the tv hooked up? hdmi, component, straight to the tv, or into the amp then tv?....what audio out? optical, digital? also what are you trying to view? local programming? cable/sat? dvd? your best bet is to ignore video on the amp and go straight to tv. can't help u more until i have more specifics.
Posted on Jan 23, 2009
hbsurfdawg
  • 95 Answers
SOURCE: Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Posted on Mar 02, 2009
Yamaha rx-v2700 digital A/V receiver will not read 3trb external hard drive when it is formatted on nts and also tried with fat32 format and does not read mp3 files. when plugged into usb port the reciever...
Hi. Is the HDD drawing too much power from the receiver (does it have its own power supply)?
You could look at the troubleshooting guide in the user manual here:
Yamaha RX V2700
Feb 14, 2018 | Yamaha RX-V2700 Receiver
Need instructions for Yamaha remote RAV206
This is the instruction manual for the whole receiver that uses that remote. There is no manual for just the remote, but this should be what you are looking for. I imagine you want to know how to use the remote with your receiver that it goes to, correct? The manual is at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5460.pdf
Thanks so much, let me know if that's not what you are looking (if that is the case) before rating my answer lower than 4 thumbs please :)
Thanks
Tim
Oct 15, 2010 | Yamaha Televison & Video
I have my system set to run with Comcast in a 5 speaker (with powered sub) home theater using HDMI and digital sound. Everything works great except when I forward or rewind on my DVR it's constatntly...
I assume you're using the Comcast remote.
You don't mention which device is changing volume (the receiver or the cable box).
Could it be that the DVR command from the remote is being misinterpreted by the Yamaha as a volume command?
Try blocking the remote eye on the receiver so it is temporarily 'blind' and test the DVR commands to see what happens to the volume.
Jun 07, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha Receiver RX-V463
Do not use HDMI thru your receiver. Go directly from the Cable box to the TV. Connect coaxial digital or optical to your receiver. Your receiver uses HDMI version 1.1 or 1.2, which is riddled with issues. If you want to read about them, Google HDMI Problems and you can read for hours. Long of the short of it is; Don't pass HDMI thru your receiver, use the receiver for audio only. Hope this answers the question. Sorry for the bad news! I'm in the industry and have been dealing with these issues for a couple years now.
Dec 16, 2009 | Yamaha RX-V463 Receiver
Yamaha Rx-v365 trying to program remote for
Press and hold "DTV" then, while holding doen DTV, press power and hold for three seconds. Release both buttons and enter your code. The front panel of the receiver will say "remote setup ok" or "NG" (no good) That being said; while you are in the process of finger acrobatics! make sure your remote is pointing in the general direction of the receiver. Yes, it's a pain, however, once your done, the Yamaha remote is a champ! Hope this helps.
Oct 01, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha remote to command Sony CD changer.
isn't that nice of them to just list the yamaha code for CD players? I sent yamaha an email about it. we'll see what they say...
have you checked out the new universal remotes that are out now?
http://universalremote.com/consumer/products.php
http://www.compuplus.com/i-Universal-Remote-Control-URC-R50-Digital-R50-Universal-Remote-Control-1028369~.html?sid=jn84494w6bxh2e2
Feb 26, 2009 | Yamaha RX-797 Receiver
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
No Sound
Three things to look for for the no sound problem:
1) Make sure the pre-out main-in couplers have jumper wires in them
2) Make sure the mute is not engaged
3) make sure the speakers wires are inserted properly. you need to unthread the five-way binding posts before inserting the wire between the post nut and receiver.
Aug 31, 2007 | Yamaha RX-V2090 Receiver
Yamaha RX-495 2 Channels Receiver Logo
35 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
