Question about Philips 60PP9352 60" Rear Projection Television
Only green when using HD component cables
When i hook up the TV to a HD box (dish network) only the green works. All other inputs seem to work. Is this repairable?
    Scholar:
  • 90 Answers
Your hookup may be wrong, you may have things reversed in your component HU. Recheck your color code on y, pb and pr.
Mr Bob
Posted on Feb 03, 2008
SOURCE:
Hooking up a Coby tv 32" to dish network but it says no signal
"No signal" usually means you are on the wrong input. Look at the back of the TV to determine what plugs were used to hook up the Dish box, it will be labeled nearby (like Video 1, Component 1 or HDMI1). Now find the "Source" or "Input" button on the TV remote (it can also be found on the TV) and set it to the input the Dish box is plugged into.
If you are using the Coax cable (the kind that screws on), go into the menu of the TV and run a "Channel Search/Scan". This will find the channel the Dish box needs to be set to on the TV.
Let me know if this doesn't work.
Jan 14, 2013 | Televison & Video
I have an older onkyo 1994 or 1995 receiver dolby pro logic with the amplifier and 6 disk changer wnd the system is clear as could be in cd mode. my problem is Ihave my xbox hooked up to the tv with hdmi...
No no no!
# 1. You need to connect all your components to your TV via an HDMI cable. For true HD and digital sound this is needed. Your TV (if its an HD TV) should have 3 or 4 HDMI inputs. So your Xbox/PS3 should be connected via HDMI cable. Your HD sat or cable box should also be connected with an HDMI cable. Same for your Blu Ray player.
#2. Now that your components are connect in a way which will enable you to see their media in either 720p, 1080i or 1080p your ready to get the Digital sound to your speakers. On the back of your TV you should (again on most all HD tv's) have a digital audio (optical) out. You need to purchase a digital (optical) audio cable and plug one end into your tv's digital audio out jack. Then plug the other end into your audio receivers digital audio in jack. You may have to go into your receivers menu to select or enable the digital/optical input. Then you should be rocking and rolling with true digital DTS, Pro Logic, Pro Logic 2 in either 5.1 or 7.1...
Think of your TV as the hub. Connect all the components with HDMI cables. And then your TV to your receiver with a digital/optical cable. It's that simple.
Never never use the red and white cables for audio. They were designed for 2 channel stereo sound. They won't deliver 5.1 or 7.1 digital sound.
Also... Don't ever hook up any component using the old "yellow" video cable if you want picture quality better than 480i resolution. They won't do HD period.
Here is a list of the popular video cables and they highest resolution.
Yellow video cables - 480i resolution
S video (super video) cable - 480p
Component video cables (red/blue/green) - up to 720p
HIgh definition multimedia interface HDMI - up to 1080p (full HD) and digital sound.
Hope this helps...
Nov 03, 2012 | Onkyo Audio Players & Recorders
What do I do to get my signal back on my westinghouse TV that is hooked up to dish cable
If no signal via the cable fitting try hooking set via one of the sets of jacks on the back (audio/video or component) to see if coax input or tuner is bad.
If the set works with a DVD etc hooked to one of those inputs and your cable is good--maybe a bad tuner in the set---also if using a box try hooking cable direct to set to rule out the box.
Mar 17, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
TV says Main no signal. Trying to hook up our Akai tv to the DISH network. Need help
Good afternoon! My name is Becki, with DISH. I hope that you have gotten this resolved, but if not, here are some steps to do so!
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. (The correct location for these on the back of the recever will have a TV 3/4 above it.)
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2) (The correct location for these on the back of the receiver will have a green TV symbol with a 1 in it.)
Please let me know if you need any further assistance!!
Becki Barned
DISH Network Customer Service
becki,[email protected]
Aug 03, 2011 | Akai LCT2715 27 in. LCD Television
I have a zenith tv older model, and have dish network, i need to know how to hook it up and switch it over so i can play it
If you have an HD receiver you will want to use one of two types of cables; you can use component cables which have five ends red, blue, green, red and white, or you can use an HDMI cable which will have one flat connection. If you have a standard definition receiver you will want to use RCA cables these have three ends red yellow white. The connections will be labeled on the television as well as the receiver. Once you get this connected hit the input/source button on your TV set if you're using RCA cables you want the TV set to video 1 or video 2. If you're using an HDMI cable then set the TV to HDMI 1or 2 using the input /source button. If you use Component cables set the TV to Y/PB/PR or component 1/2.
Daniel Busa
Mar 09, 2011 | Zenith Z50P3 50 in. Plasma TV
Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
I just got a Vizio 37" TV from Walmart.When I turn it on, I get a blue screen that says No Signal. Help.I have Dish Network. What am I doing wrong?
Check that the connection where the dish box is connected to the TV is the selected input on your TV.
You should have either a component connection (5 cables) or HDMI (1 cable) connecting the dish box to your TV. The VX37 has two component inputs and two HDMI inputs (if I remember correctly). Use the INPUT button on your remote to select the correct input.
Once you confirm this and still have problems, post a response and I will follow-up.
Dec 21, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Proron pltv-4250 no signal
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
Nov 22, 2008 | Protron PLTV-4250 42 in. LCD Television
I purchased the hdtv model DP32648 at walmart, I hooked it up, it is on and working , But some stupid guy told me I needed a cable called HDMI, OK So I have it But I have Dish Network, their is no place to...
ya dish network reg box isnt hd ok u need call dish get hdtv box then u can use hdmi cable to get hi end picture ok for now use cox cable like u do to u can upgrade dish hd sumday k
Oct 15, 2008 | Televison & Video
Philips 60PP9352 60" Rear Projection Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
